Thread: Esp sensor g419 replacement help needed
  1. Exclamation Esp sensor g419 replacement help needed
    Mar 2014
    A, A
    hi guys
    i plugged in vcds and these are the fault codes i received
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03G 906 016 GC HW: 03G 906 016 GC
    Component: R4 2,0L EDC G000CG 9887
    Revision: --H02--- Serial number:
    Coding: 0000076
    Shop #: WSC 00654 210 91806
    VCID: 6ADB2423458A324E2A7-803F
    1 Faults Found:
    006215 - Please check DTC Memory of ABS Controller
    P1847 - 000 -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 85
    Reset counter: 255
    Mileage: 230102 km
    Time Indication: 0
    Date: 2014.03.29
    Time: 16:40:12
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.70 V
    Bin. Bits: 00101000
    Torque: 0.0 Nm
    Bin. Bits: 00000100
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
    Component: ESP 8.0 front H05 0090
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020856
    Shop #: WSC 02325 785 00200
    VCID: 2C57E23B8FFEEC7E18B-8079
    1 Fault Found:
    00493 - ESP-Sensor Unit (G419)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 153
    Mileage: 230908 km
    Time Indication: 0
    Date: 2005.09.21
    Time: 18:46:29
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0282
    Hex Value: 0x0043
    Hex Value: 0x018F
    Hex Value: 0x00FF
    i wish to install the esp sensor myself. I have found one second hand on ebay and it is part number 4f0-907-637. I am wondering if this is the correct part replacement for my esp sensor
    By the way i have an audi a6 2006 2.0 tdi
    and i understand that the esp sensor is under the centre console
    My question is that how do i use vcds to check measuring value blocks to check the wiring between j104 and the esp sensor
    and my second question is upon replacing the esp sensor with the second hand one from ebay, do i need to calibrate it and if so how do i calibrate it?
    would i need to calibrate the steering sensor aswell even though i am not replacing it
    please can someone help me with this
  2. Re: Esp sensor g419 replacement help needed
    46 Post(s)
    Are you having any issues? Which version of vcds are you using?
  3. Re: Esp sensor g419 replacement help needed
    Mar 2014
    A, A
    thank you for replying
    I'm using the latest version of vcds i believe, 12.12
    Im not having any issues when i drive the car, well i haven't noticed any but the esp fault warning comes on every time i start the car and the traction control light is always on as well and it has been doing this for the past year so i thought that i would try to fix it.. i just need help on how to fix it
    I went o holiday and then when i came back, the cars brakes had like frozen so after i eventually got them free by trying to move the car back and forward and revving the car, the cars brakes got free but since then the esp fault warning has been occurring every time i start the car
  4. Re: Esp sensor g419 replacement help needed
    Nov 2012
    Somerset UK
    Had something similar on the Jag which led to an ABS/ESP fault, wasn't any sensor but the ABS ECU itself which needed to be reworked (£150 with a lifetime warranty) at a place in Wales.
    Naturally always go with the cheapest option to fix which may be the sensor, or not.
    Am assuming you cleared the DTC's?
  5. Re: Esp sensor g419 replacement help needed
    46 Post(s)
    00493 - Ross-Tech Wiki
    Look at that. I would advise buying new parts from Audi and getting a specialist to do the work.
  6. Re: Esp sensor g419 replacement help needed
    Mar 2014
    A, A
    Yes i cleared the DTC's but they appear as again as soon as i start the car
  7. Re: Esp sensor g419 replacement help needed
    Mar 2014
    A, A
    i have looked at that
    and that is why i am asking what measuring blocks i need to check and how to check them
  1. Question ABS/ESP Modulator replacement guide
    By gunnag in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-10-2013, 01:44 PM
  2. ESP Sensor Unit G419
    By TimA6QSline in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-07-2013, 05:32 PM
  3. Please Help a4 b6 b pillar crash sensor replacement (help with buying the replacement)
    By Train050 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-04-2013, 10:35 PM
  4. update re-esp light some help needed
    By roy2001 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-08-2010, 02:58 PM
  5. Lateral ESP sensor
    By micky in forum Audi A3 - Archive Topics
    Last Post: 03-10-2007, 10:30 PM
