Thread: Audi Q7 bluetooth
Results 1 to 9 of 9
  1. Audi Q7 bluetooth
    Sep 2008
    Arbroath, Scotland
    Hi, I'm looking for someone to confirm for me if the bluetooth module for an Audi Q7 with MMI 2G. I believe it's under the front right hand seat.
    CURRENTLY - Audi Q7 3.0TDI S-Line
    PREVIOUSLY - Passat 2.0TDI R-Line, Golf Mk3 GTI, S4, A3 1.8T, POLO 1.4L
  2. Re: Audi Q7 bluetooth
    May 2007
    knee deep in clunge
    14 Post(s)
    yep under drivers seat
  3. Re: Audi Q7 bluetooth
    Sep 2008
    Arbroath, Scotland
    Perfect, cheers for that a8 tech.
    Will look into getting the seat out over the next couple of days to fit the bluetooth module.
    You wouldn't also know where the best place to tie in the 12v, ground and k-diagnose is? I have the ami module in the armrest but insure how easy access to the back of it is.
  4. Re: Audi Q7 bluetooth
    May 2007
    knee deep in clunge
    14 Post(s)
    Are you retro fitting this
    If so pick your optical and kwire + live and earth from the media player in the dash and fit the unit behind the glovebox
  5. Re: Audi Q7 bluetooth
    Sep 2008
    Arbroath, Scotland
    Yeah going to attempt a retro fit of this. Wasn't sure if there was room for it there in the Q7. It certainly seems like a easier place to get to than removing the front seat.
    Thanks again tech, I'll let you know how I get on with it.
  6. Re: Audi Q7 bluetooth
    Sep 2008
    Arbroath, Scotland
    That's my bt module now fitted, took most of the afternoon cause I had trouble getting the CD changer out connect the power & k-line to. For most of the install I loosely followed A6-Chris's detailed write up for the install he did. I currently have the bt module mounted in the same place as Chris did in the write up but may need to move it slightly cause it seems to be activating the parking brake sensor randomly when either braking or turning. But the main thing is that it's fitted & working.
  7. Re: Audi Q7 bluetooth
    May 2014
    toronto
    Would the Bluetooth module be located in the same place on a left hand drive q7? under the drivers seat?
    Thanks in advance!
  8. Re: Audi Q7 bluetooth
    Sep 2008
    Arbroath, Scotland
    I believe in a left hand drive the battery is under the drivers seat & the bluetooth is under the passengers seat.
  9. Re: Audi Q7 bluetooth
    May 2014
    toronto
    Thank You!
  1. Question Audi A3 Bluetooth
    By JONDON88 in forum In Car Entertainment
    Last Post: 21-01-2014, 07:46 PM
  2. Fiiting Audi Bluetooth to S4 B8 - Will audi unit from A3 8P work ?
    By jeznewsome in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 13-01-2013, 09:27 PM
  3. bluetooth in audi A4
    By suziesincy in forum In Car Entertainment
    Last Post: 17-10-2012, 09:18 AM
  4. Audi A5 Bluetooth Help
    By geoffers10 in forum In Car Entertainment
    Last Post: 14-07-2010, 10:52 AM
  5. Bluetooth and Audi
    By Colin Hughes in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-06-2008, 05:19 PM
