Thread: 2008 A6 C6 3.0TDi Misfire
  1. 2008 A6 C6 3.0TDi Misfire
    Nov 2006
    Southampton
    Hi All,
    My A6C6 has 72000 on the clock, serviced on the dot, recently noticed a misfire at startup, very short, but tacho needle was jumping.
    Drove on to the motorway and home 35 miles no problem no misfire, same again the next day.
    Had it scanned, fault code for no 6 glow plug, so that would explain running lumpy at startup, but I also had it once on the motorway.
    Decided it might be crappy fuel, but today no misfire or lumpy running glow plugs on order, thought about some injector cleaner, but Audi don't recommend it.
    Ideas anyone?
    Gazza57
  2. Re: 2008 A6 C6 3.0TDi Misfire
    46 Post(s)
    When was the fuel filter last done?
    Bad diesel and a clogged filter will upset things.
  3. Re: 2008 A6 C6 3.0TDi Misfire
    Nov 2006
    Southampton
    fuel filter done ar last service, suspect a tank of contaminated diesel as I don't get the misfire all the time
    Glow plugs renewed tomorrow
  4. Re: 2008 A6 C6 3.0TDi Misfire
    Nov 2012
    Somerset UK
    Did you see them change it/did they give you the old one back, or is it just on the invoice?
  5. Re: 2008 A6 C6 3.0TDi Misfire
    Nov 2006
    Southampton
    No worries on that score
    the indy I use is 100% kosher,
  1. Please Help A4 2.0TDI Misfire/Judder around 2000rpm
    By A42.0TDI in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-11-2017, 12:12 PM
  2. 4.0tdi power loss misfire
    By deutsch in forum A8 - S8 - V8
    Last Post: 24-08-2013, 05:15 PM
  3. 2008 A6 2.0 tdi bre , Misfire , hesitation , lack of power
    By kenmurray in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-03-2013, 01:48 PM
  4. 2.0tdi misfire on idle !!!!
    By tee2803 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-06-2008, 07:16 PM
  5. 2.0tdi misfire on idle !!!!
    By tee2803 in forum Golf MK5 - 2004 - 2009
    Last Post: 16-03-2008, 10:21 PM
