Thread: syphon the fuel tank.
Results 1 to 10 of 14
  1. syphon the fuel tank.
    is it possible to get a pipe down a 2001 passats fuel tank so I can drain it ???
    im selling the car and put £ 50 of derv in , id like to put in my new car .
  2. Re: syphon the fuel tank.
    ill answer this one, yes you can get a pipe down m8 . only a narrow pipe will fit and return flow into a container etc is very slow , it took a good 30 mins to get 35 litres from my tank . but well worth the time .
  3. Re: syphon the fuel tank.
    Quote Originally Posted by passat 130 tdi View Post
    Disconnect the fuel line at the filter and turn the key (not against the stop, no need to run the engine) the fuel pump will
    pump the fuel out for you.
  4. Re: syphon the fuel tank.
    Pembrokeshire
    22 Post(s)
    the pump will run for 1 second and pump an egg cup full out until you turn the ign off and back on again. you can bypass the fuel pump relay so it runs continuously but thats a faff. i just disconnect a pipe from the fuel filter and suck it out using my oil extractor.
  5. Re: syphon the fuel tank.
    i liked my own reply
  6. Re: syphon the fuel tank.
    But an egg cup per second would be quicker!
  7. Re: syphon the fuel tank.
    Feb 2007
    Poole
    How many egg cups to fill a litre?? More than 48 I bet
  8. Re: syphon the fuel tank.
    lads !!! lads !!! I sucked the tank dry in 30 mins , its all over now , let it go
  9. Re: syphon the fuel tank.
    Oct 2005
    I want to know what you sucked it into - 35 litres is a lot of egg cups!
  10. Re: syphon the fuel tank.
    an old beer making bucket.
  1. syphon fuel
    By steve67 in forum Golf MK6 - 2009 - 2013
    Last Post: 28-04-2014, 08:17 PM
  2. Can you syphon out of the fuel tank 3.0TDi
    By MarkTM in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-04-2013, 10:02 AM
  3. what can cause oil to go into fuel tank and fuel in sump ( blb engine )
    By imi in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-04-2013, 08:44 PM
  4. Question Fuel pump not working: Fuel tank pd130
    By Saturn in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-03-2012, 08:43 PM
