Thread: Audi A3 8P2 2009 Plate
  1. Audi A3 8P2 2009 Plate
    Apr 2014
    Bath UK
    I bought an Audi A3 2009 plate (8P2 chassis) I want to fit an after market head unit (double din) to it.
    Alpine CDE-W235BT (//http://www.caraudiocentre.co.uk/product_m-alpine-cde-w235bt_p-27486.htm)
    After removing the original OEM Chorus unit, I have found I have a quadlock connection
    and an antenna i think.
    The Car has no amp according to audi when I phoned them. Only two front door speakers, No Cd changer and No Steering wheel controls.
    So my question is, I'm unsure what adapter I need in order to connect the unit to the car. Quadlock to ISO?
    Thanks.
  2. Re: Audi A3 8P2 2009 Plate
    tanuie Guest
    Hi Talk to car audio they will be able to put you right on this matter, I have used this company on occasions.
  3. Re: Audi A3 8P2 2009 Plate
    Oct 2005
    Correct, you'll need a Quadlock to ISO adapter.
    Connects2 - http://www.connects2.co.uk/C2/C2Rang...=18&Modelid=23
    Autoleads - http://productfinder.autoleads.co.uk...3&id=49&mode=2
  4. Re: Audi A3 8P2 2009 Plate
    Apr 2014
    Bath UK
    Could you recommend a part number? As I'm confused about which one I'd need? and would I have to wire it to an ignition wire/switch? thanks
  5. Re: Audi A3 8P2 2009 Plate
    46 Post(s)
    You may have to run one of the wires to an ignition switched source as the original radio uses canbus to switch on and off from memory.
  1. Audi Allroad A6 2.7T 55 Plate skid plate question
    By Markymark144 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-06-2013, 02:22 PM
  2. Question Audi a4 2009 with concert 3
    By kennyd167 in forum In Car Entertainment
    Last Post: 21-05-2012, 08:38 AM
  3. Hello from new 2009 Audi A3 owner
    By Coralwood59 in forum New Member Introductions
    Last Post: 04-12-2011, 08:23 PM
  4. 2009 audi a4 cabriolet, does ii have the new lights
    By marc5180 in forum Chat - Anything with wheels
    Last Post: 19-02-2009, 11:08 PM
