Thread: Golf GTI MK6 Cruise Control retrofit
Results 1 to 10 of 15
  1. Golf GTI MK6 Cruise Control retrofit
    Nov 2013
    Bangor N.I
    Hello all,
    I recently bought a 2010 (july) mk6 Golf GTI (without cruise control), I thought I could do without the cruise control but I really miss it. I contacted the VW dealer that I bought the car from and was informed that it could be fitted to my car no problem (this was after they checked the chassis number etc). They ordered up the stalk and the car was booked in today to have the work done. I was told the work would take 1-2 hours, after about 3/4 of an hour the workshop manager came to the waiting area to inform me that they could not carry out the job as there was a coding compatibility issue....
    I just wanted to ask if anyone here has had this option retrofitted successfully? I have done a lot of searching tonight and there is a lot of conflicting info regards this. I was wondering if the car could come factory fitted with this option then why can it not be installed afterwards?
    Any help or advice would be appreciated.
    Chees
  2. Re: Golf GTI MK6 Cruise Control retrofit
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    I asked my dealer if they could fit cruise control they said it depends on the build date as in 2010 they added another £400 module so it makes it more expensive.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  3. Re: Golf GTI MK6 Cruise Control retrofit
    46 Post(s)
    Steering wheel module needs to be checked whether its compatible with cruise, I suggest getting somebody to check this with VCDS and cross reference the PN on the RT website.
    If VW checked via your VIN then I can't see why they can't code it.
    You should fit it yourself, it's not hard to do.
  4. Re: Golf GTI MK6 Cruise Control retrofit
    Nov 2013
    Bangor N.I
    Ok Chris, i have VCDS myself. Can you tell me what i need to do to check the steering wheel module with it?
    VW Tiguan 2.0 TDI 4 Motion 2016 manual
    Full VCDS Available
  5. Re: Golf GTI MK6 Cruise Control retrofit
    Sep 2008
    mostly in the garage
    just post a scan of address 16 on here then people can compare with a vehicle of similar build date but with the additional cruise control.
    as said there may well be issues with controllers and subsystems.......there are various additional controllers for MFSW switches.
    makes you wonder whether some dealers know what they were doing.
    if i'm correct as well as recoding steering 16 , engine 01, abs 03 and possibly instruments 17 need recoding too.
  6. Re: Golf GTI MK6 Cruise Control retrofit
    Nov 2013
    Bangor N.I
    Ok here it is:
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 507 BB HW: 5K0 953 549 D
    Component: Lenks.Modul 007 0080
    Revision: -------- Serial number: 90422JEK0005C
    Coding: 108A040000
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_SMLSNGKUDS A05001
    ROD: EV_SMLSNGKUDS_SE36.rod
    VCID: 71EFB222A0FCDB96649-8024
    Multi Function Steering Wheel Control Module:
    Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H05 0010
    Serial number: 0004313
    Coding: 820000
    No fault code found.
  7. Re: Golf GTI MK6 Cruise Control retrofit
    Sep 2008
    Quote Originally Posted by mckee25 View Post
    Ok here it is:
    I have cruise but a different age and model (so different module) so can't help with reference to your gti, hopefully someone has a similar car that can compare.
    In the meantime you if you look in the coding in that module does it open the long coding helper, if so is there a tick box for cruise control? If there's no option then i guess that's the issue.
    I also noticed on the RossTech site that attempts to retrofit cruise have been complicated by missing wiring on some models (my 2010). As you have a gti i'd be surprised if this was your problem but you never know?
  8. Re: Golf GTI MK6 Cruise Control retrofit
    46 Post(s)
    A snippet from - Steering Wheel Control Module Versions - Ross-Tech Wiki
    Gives
    5K0-953-549-D Highline #1
    #1 being - : Depending on the hardware version of this module, it MAY or MAY NOT allow Cruise Control Retrofitting, so replacing the Steering Wheel Control Module may be required.
    As above check if it allows coding for CC and report back.
  9. Re: Golf GTI MK6 Cruise Control retrofit
    Nov 2013
    Bangor N.I
    ok, so had a look at the module through VCDS and there is no option in the coding (using the long coding helper) for cruise control...
    So i'm also looking at now having to change the module to allow cruise control to be fitted, does anyone know what sort of price these are? I really want the cruise control option but if it's going to be over £400, well it might just not be worth it.
    I have been in touch with Walsh Motors (Belfast) to see what they can come up with, have to call them back tomorrow.
  10. Re: Golf GTI MK6 Cruise Control retrofit
    46 Post(s)
    About £75
    VW steering wheel module 5K0953549B 5K0 953 549 B caddy touran golf jetta | eBay
    5K0-953-549 Lowline -
    5K0-953-549-A Midline #1
    5K0-953-549-B Highline -
    5K0-953-549-C Midline -
    1 1 0
  1. Retrofit Cruise Control
    By Desmo in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-11-2012, 10:05 PM
  2. Cruise Control Retrofit
    By OldBoy Racer in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 31-08-2012, 08:34 PM
  3. Cruise Control retrofit
    By Nbaddy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2009, 10:21 PM
  4. Cruise control retrofit?
    By css in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-12-2009, 10:06 PM
  5. Retrofit Cruise Control
    By trainer555 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-06-2009, 09:15 PM
