Thread: Remote fob help !! Please!!
Results 1 to 9 of 9
  1. Remote fob help !! Please!!
    Aug 2007
    Got myself a fob not the key for my 96/97 SE passat from ebay, right part number according to VW - yet when I follow the key in the ignition and door setup nothing happens.
    Does fob have to be introduced to car by computer or am I missing something, any help would be greatly appreciated.
  2. Re: Remote fob help !! Please!!
    Sep 2007
    Liverpool
    Hi I also got a key & remote fob from EBAY, I had the blade cut to match (it will turn over the car & open the doors). I programmed the remote locking & unlocking no problem, the problem is that the immobiliser has to be programmed to the key. I also made sure the part number matched the original key I alreadt had. I took my key to local VW dealer & they said the key could not be programmed to the immobiliser, although I think they were lying. If i have any luck I will let you know, DITTO.
    Peter G
  3. Re: Remote fob help !! Please!!
    Sep 2007
    Liverpool
    Peter G
  4. Re: Remote fob help !! Please!!
    Aug 2007
    The problem i have is I'm really not sure wether my car has the remote central locking feature.
    Although its an SE it didn't come with a remote, so i tracked down the remote that would have been for my age car and bought that. It may be I'm barking up the wrong tree but and the car doesn't have it. I've tried the key in the door, key in the ignition thing a few times now but with no success.
    That is why I was wondering if I had to introduce it to the car. But if you managed to programme your own remote then I guess it must be my car.
  5. Re: Remote fob help !! Please!!
    Canada
    Quote Originally Posted by PETER G View Post
    Hi I also got a key & remote fob from EBAY, I had the blade cut to match (it will turn over the car & open the doors). I programmed the remote locking & unlocking no problem, the problem is that the immobiliser has to be programmed to the key. I also made sure the part number matched the original key I already had. I took my key to local VW dealer & they said the key could not be programmed to the immobiliser, although I think they were lying. If i have any luck I will let you know, DITTO.
    Peter G
    I have successfully programed a key from ebay to my car, first get the right key which you have then you need the SKC code to login to the immobiliser and match the keys.
    Quote Originally Posted by andyha2000 View Post
    check the options list in the boot online and it will tell you if remote locking is fitted
  6. Re: Remote fob help !! Please!!
    Aug 2007
    Thanks for the reply, where abouts is the list of codes in the boot and is there a list of what they are somewhere? - Thanks
  7. Re: Remote fob help !! Please!!
    Canada
    there is a link on the forum somewhere where you can put the option codes in for your car. But i Can't find it
    All VW/Audi cars have a sticker in the boot listing engine code and options picked at time of purchase. Usually in the spare wheel well
  8. Re: Remote fob help !! Please!!
    Aug 2007
    Thanks for your help, I'll check the codes in the morning. In the meantime I found this link for codes from an earlier posting by you to check the options on a car.
    See here http://igorweb.org/equidec/Default.aspx
    Thanks again.
  9. Re: Remote fob help !! Please!!
    Aug 2007
    Is this an exhaustive list of what my car should have. I checked the codes with the checker and it lists stuff my car has however it doesn't list anything at all to do with the electrics pack or the central locking.
    Looks like I'll be putting the fob back on ebay - Ho Hum
  1. spare remote key
    By jrw in forum Audi A3 - Archive Topics
    Last Post: 04-08-2007, 06:51 PM
  2. How do I reprogram the remote key ?
    By chrisjmcqueen in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-06-2007, 06:11 PM
  3. Remote key fob
    By davedru in forum Audi A4 - Archive Topics
    Last Post: 06-06-2007, 10:58 AM
  4. Remote key fob
    By davedru in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-05-2007, 08:11 PM
  5. Remote CL
    By welshdragon1611 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-01-2007, 01:30 PM
