Thread: 1.8T remap and brakes!
Results 1 to 10 of 13
  1. 1.8T remap and brakes!
    Aug 2007
    Hi, I have just bought a year 2000 quattro sport A4 saloon, with the 1.8T engine. I was hoping to fit a Steinbauer tuning box, but have just found out that they dont do one for this engine, as its too early. Also e-mailed a local revo dealer and they dont do a serial port downolad for this model. Anyone point me in the direction of someone who can do this in the Sufffolk, Norfolk, north essex area? Also thinking of a brake up-grade, to the VAG 312mm discs. Will i need to change calipers, or just use different carriers? Thanks in advance, Mark
  2. Re: 1.8T remap and brakes!
    133 Post(s)
    1986 Post(s)
    I have never done a 312 conversion on an 8D A4 but the 2001 8E A4 was available with 312's although the caliper carrier used M14 bolts. As for a power increase, send your ECU to Awesome and they will APR chip it for you.
  3. Re: 1.8T remap and brakes!
    Aug 2007
    Thanks crasher, is that Awesome at Thurrock, Essex? if so thats not too bad.
  4. Re: 1.8T remap and brakes!
    133 Post(s)
    1986 Post(s)
    They are in Manchester
  5. Re: 1.8T remap and brakes!
    Aug 2007
    Ok mate, rather not send the ECU, and Manchesters a bit of a trek. Cheers, Mark
  6. Re: 1.8T remap and brakes!
    Feb 2007
    UK (London)
    There is a Group Buy going on here that will map your car for around £250
    04 Audi A4 B6 1.8TQ S-Line 190bhp 6 Speed Duel SMIC
    Milltek Exhaust|VMR boost Gauge|SP51 K04-15 Outlaw (K04-23+)|Samco Sport DV|034 Sport CAT|
    To be fitted: B7 RS4 F-Brakes|B5 RS4 R-Brakes|SB Stage4| TT MAF| 380 inj|
  7. Re: 1.8T remap and brakes!
    Feb 2007
    UK (London)
    Oh and read up on this.
    Link
  8. Re: 1.8T remap and brakes!
    Aug 2007
    Thanks Docurley, interesting link. I presume as mine is a late face-lift car (2000my), it should be possible to use the serial port? i was suprised Revo did'nt do it. i will check out the group but you mentioned. Thank, Mark
  9. Re: 1.8T remap and brakes!
    Feb 2007
    UK (London)
    Depends if you are drive by wire or not.
    If you have a normal throttle wire that you can pull to rev the engine then no you can't and you are none drive wire and will have to have a chip dropped in.
  10. Re: 1.8T remap and brakes!
    Aug 2007
    Engine code is AJL and it is conventional throttle cable. Any reason this would be so, I thought Audi had gone over to drive by wire by the time my car was built (03/2000)? Wheres the Ecu on the A4, by the way?
  1. Remap or not - 130 PD TDi?
    By Paul Jay in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-08-2007, 07:45 AM
  2. 0-60 after a remap?
    By carrmrc96 in forum Archive posts
    Last Post: 13-07-2007, 06:44 PM
  3. Remap - try before you buy!
    By Gavin78 in forum Archive posts
    Last Post: 26-06-2007, 10:36 PM
  4. remap
    By garying3980 in forum Passat - Archive Topics
    Last Post: 26-02-2007, 10:51 AM
  5. A4 Remap
    By marcus in forum Audi A4 - Archive Topics
    Last Post: 20-02-2007, 07:03 PM
