Thread: Throttle Valve.
Results 1 to 8 of 8
  1. Throttle Valve.
    Oct 2009
    Dublin Ireland
    Hello Chaps,
    I recently had reason to repair a number of faults on my 2005 2.7 TDI Quattro Avant with 185,000 miles on the clock.
    I bought a pair of swirl flap units from Stan at Airshox, (sales@airshox.eu) which were €100 each. Arrived promptly and are perfect. I'd recommend them. Anyway, my local Audi trained indy installed them, as well as the link arms etc. and also the EGR valve. (trying to get rid of slightly whitish / grey smoke at idle.) The scans showed up a number of faults, 2 turbo, and a lot of Throttle Valve faults and only 2 glow plugs left working... Sorry, can't copy printout. My local Dealer is quoting €430 for a new valve, (ouch) when apparently it is only the nylon gears which are worn. Does anyone know if these gears can be purchased anywhere?
    On another topic, had the condensation in my left rear lens, giving intermittent bulb faults, and did the drill a few holes trick, only 3 actually, hey presto, condensation gone the following day, although its been really wet.
    Fergus
  2. Re: Throttle Valve.
    Mar 2008
    11 Post(s)
    Not going to pretend to know engine parts but if its the same as a throttle body, I changed mine a few months back
    http://www.eurocarparts.com/ecp/c/Au...e269a4e&000329
    Paid under 250 at the time I think but there were a whole load of promotions going on at the time.
    £435 was what Audi quoted me too for parts only
  3. Re: Throttle Valve.
    Nov 2012
    Somerset UK
  4. Re: Throttle Valve.
    Oct 2009
    Dublin Ireland
    Thanks for that..
    Unfortunately mine is a 4 pin connector...
    fergus
  5. Quattro 2.7 limp mode.
    Oct 2009
    Dublin Ireland
    Hello Chaps,
    Finally got a cable. Spat out the following.
    Can anyone tell me what the probable diagnosis is? Am going into limp mode intermittently (once or twice a week) and the engine symbol is lit up. I have replaced the 2 swirl flap assemblies (from Airshox) and the linkages.
    Is there an easy way to find the fault codes? It seems I would have to trawl through all of the Ross Tech code no's to find ones related to mine.
    Fergus
    Code:
    Address 01: Engine        Labels: Redir Fail!
       Part No SW: 4F2 910 401 P    HW: 4F0 907 401 B
       Component: 2.7L V6TDI  G000AG  0010
       Revision: --H01---    Serial number:
       Coding: 0011372
       Shop #: WSC 02334 785 00200
       VCID: 2B55E1278AF0EB4608F-807E
    7 Faults Found:
    005445 - Throttle Valve Controller
                   P1545 - 002 - Malfunction
                 Freeze Frame:
                        Fault Status: 01100010
                        Fault Priority: 0
                        Fault Frequency: 57
                        Reset counter: 255
                        Mileage: 296241 km
                        Time Indication: 0
                        Date: 2014.03.22
                        Time: 16:37:59
                 Freeze Frame:
                        RPM: 777 /min
                        Torque: 39.0 Nm
                        Speed: 0.0 km/h
                        Voltage: 13.83 V
                        Duty Cycle: 40.6 %
                        Bin. Bits:    000
                        Mass Air / Rev.: 475.9 mg/str
    005662 - Glowplug for Cylinder 5 (Q15)
                   P161E - 001 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01110001
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 296241 km
                        Time Indication: 0
                        Date: 2014.03.22
                        Time: 17:19:29
                 Freeze Frame:
                        RPM: 756 /min
                        Torque: 109.2 Nm
                        Speed: 0.0 km/h
                        Duty Cycle: 1.0 %
                        Voltage: 13.60 V
                        Duty Cycle: 21.7 %
                        Temperature: 45.0°C
    005663 - Glowplug for Cylinder 6 (Q15)
                   P161F - 001 - Open Circuit
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 296241 km
                        Time Indication: 0
                        Date: 2014.03.22
                        Time: 17:19:29
                 Freeze Frame:
                        RPM: 756 /min
                        Torque: 109.2 Nm
                        Speed: 0.0 km/h
                        Duty Cycle: 1.0 %
                        Voltage: 13.60 V
                        Duty Cycle: 21.7 %
                        Temperature: 45.0°C
    013128 - Control Circuit for Controller for Turbocharger 1 (J724)
                   P3348 - 004 - Electrical Malfunction - Intermittent
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 0
                        Fault Frequency: 49
                        Reset counter: 255
                        Mileage: 296672 km
                        Time Indication: 0
                        Date: 2014.03.26
                        Time: 08:14:51
                 Freeze Frame:
                        RPM: 819 /min
                        Torque: 109.2 Nm
                        Speed: 10.1 km/h
                        Temperature: 14.4°C
                        Duty Cycle: 80.9 %
                        Voltage: 13.83 V
                        Duty Cycle: 89.2 %
    012696 - Control Circuit for Intake Manifold Runner (Bank1)
                   P3198 - 002 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 0
                        Fault Frequency: 25
                        Reset counter: 255
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 0 /min
                        Torque: 0.0 Nm
                        Speed: 0.0 km/h
                        Voltage: 11.78 V
                        Duty Cycle: 0.4 %
                        Duty Cycle: 84.8 %
                        Duty Cycle: 20.5 %
    000565 - Boost Pressure
                   P0235 - 001 - Regulation Range not Reached - Intermittent
                 Freeze Frame:
                        Fault Status: 00110001
                        Fault Priority: 0
                        Fault Frequency: 31
                        Reset counter: 255
                        Mileage: 296891 km
                        Time Indication: 0
                        Date: 2014.03.27
                        Time: 12:57:26
                 Freeze Frame:
                        RPM: 2184 /min
                        Torque: 276.9 Nm
                        Speed: 53.8 km/h
                        Absolute Pres.: 2203.2 mbar
                        Absolute Pres.: 1142.4 mbar
                        Mass Air / Rev.: 528.8 mg/str
                        Temperature: 8.1°C
    005659 - Glowplug for Cylinder 2 (Q11)
                   P161B - 001 - Open Circuit
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 300247 km
                        Time Indication: 0
                        Date: 2014.04.28
                        Time: 08:16:25
                 Freeze Frame:
                        RPM: 819 /min
                        Torque: 124.8 Nm
                        Speed: 2.2 km/h
                        Duty Cycle: 1.0 %
                        Voltage: 13.83 V
                        Duty Cycle: 21.7 %
                        Temperature: 12.6°C
    Readiness: 1 4 0 0 0
    Last edited by Guest 2; 29-04-2014 at 12:54 PM. Reason: adding code tags around autoscan, moved post into previous thread
  6. Re: Quattro 2.7 limp mode.
    46 Post(s)
    Did you clear and rescan?
  7. Re: Quattro 2.7 limp mode.
    Oct 2009
    Dublin Ireland
    Thanks Chris,
    Yes, the above is the second scan. The engine symbol went off, but came on again this morning immediately when I started it.
    fergus
  8. Re: Quattro 2.7 limp mode.
    46 Post(s)
    A log of the fault will still remain in the ECU
    Here are some rosstech links which should help
    16619/P0235/000565 - Ross-Tech Wiki
    19804/P3348/013128 - Ross-Tech Wiki
    17953/P1545/005445 - Ross-Tech Wiki
  1. EGR Valve/Throttle Valve, where is Fuse F8??
    By robtuke in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-11-2013, 07:43 AM
  2. Throttle control valve
    By spudgun101 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-03-2011, 11:38 PM
  3. throttle valve problem
    By simonavo in forum A8 - S8 - V8
    Last Post: 03-03-2011, 06:53 PM
  4. Throttle Valve Controller
    By animal in forum Polo - Derby - Lupo - Fox
    Last Post: 22-03-2010, 10:12 PM
  5. Please Help Throttle Control Valve ???
    By 28ash in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-05-2009, 09:23 PM
