Thread: Cruise Control on 05 Highline
Results 1 to 8 of 8
  1. Exclamation Cruise Control on 05 Highline
    Sep 2007
    been to see a 05 plate 130bhp Highline today / didn't have cruise fitted
    do they come with cruise control as standard or was it an option
    sure I read some ads that they did
    anyone with a link to the specs for a May 05 Highline?
  2. Re: Cruise Control on 05 Highline
    133 Post(s)
    1982 Post(s)
    I think it was an option but it is relatively simple to fit. The kit (harness and witch) is 3B0 998 527 C and costs £65 inc. VAT from any VAG dealer and you need to go into the engine ECU using VAG-COM to login and enable the cruise function. Some I have done have already been enabled. It is an easier install than a Golf 4 as well. The only tricky part is not disturbing the steering angle sensor whilst the wheel is off.
  3. Re: Cruise Control on 05 Highline
    Sep 2007
    this item @ £47.46 + vat
    if the ecu cruise function is enabled already does the cruise work OK once the stalk is fitted or is it best to have it checked out @ a service centre?
  4. Re: Cruise Control on 05 Highline
    133 Post(s)
    1982 Post(s)
    If "G" (for "Geschwindigkeitsregelanlage", literally “Speed control governor”) is present at the end of the ECU identification then the cruise will work immediately. Otherwise it takes minutes to enable IF you have the equipment like VAG-COM but it must be a full and registered version of VAG-COM or it won't work.
  5. Re: Cruise Control on 05 Highline
    Sep 2007
    capable of fitting the cruise control stalk myself but what does it cost to have cruise enabled should it need doing?
  6. Re: Cruise Control on 05 Highline
    Sep 2007
    have you got a link to a picture of this "G" ?
  7. Re: Cruise Control on 05 Highline
    Jun 2006
    UK, Mids
    The G appears in VAG COM.
  8. Re: Cruise Control on 05 Highline
    133 Post(s)
    1982 Post(s)
    As an example, if one of my customers fitted their own stalk/wiring and asked me to enable the cruise, I would charge £25 ish which is a standard fault code read charge.
  1. Cruise control
    By estartit in forum TT - 8N Forum - 1998 - 2006
    Last Post: 06-05-2008, 10:27 PM
  2. Cruise Control / Climate Control
    By Cian_ie in forum Archive posts
    Last Post: 27-01-2008, 08:47 AM
  3. cruise control
    By 1.8t bus in forum Chat - Anything with wheels
    Last Post: 06-09-2007, 10:03 PM
  4. Anyone got cruise control?
    By peterwatkins99 in forum Chat - Anything with wheels
    Last Post: 06-09-2007, 08:01 AM
  5. Cruise control
    By Jimchoc in forum Passat - Archive Topics
    Last Post: 12-09-2006, 08:28 PM
