Thread: Polo Timing Issue 1.2 6v BBM
  1. Polo Timing Issue 1.2 6v BBM
    Mar 2014
    suffolk
    hello, i have a polo with engine management on, below is the vcds report. Just wondering if any one else has come across similar problems
    Tuesday,25,March,2014,08:24:11:06086
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.2.0
    Data version: 20140212
    Mileage: 42390km-26339mi Repair Order:
    Chassis Type: 9N (6N - VW Polo (1995 > 2002))
    Scan: 01 02 03 08 15 17 19 25 41 45 46 55 56
    VIN: WVWZZZ9NZ8Y188336 Mileage: 42390km/26339miles
    Address 01: Engine (XXX) Labels: Redir Fail!
    Part No: 03D 906 023
    Component: SIMOS91 1.2l 2V 5415
    Revision: --H04--- Serial number: VWZ7Z0H6468542
    Coding: 0000071
    Shop #: WSC 00050 210 182023
    VCID: DBB5C9B91932C6C62E5-5124
    1 Fault Found:
    16726 - Camshaft Position Sensor (G40)
    P0342 - 009 - Signal too Low - Intermittent
    Freeze Frame:
    RPM: 4544 /min
    Mass Air / Rev.: 436.0 mg/str
    Bin. Bits: 00001000
    Temperature: 87.0°C
    RPM: 832 /min
    Mass Air / Rev.: 114.5 mg/str
    Bin. Bits: 00000100
    Temperature: 85.5°C
    Readiness: N/A
    Address 03: ABS Brakes Labels: 6R0-907-37x-ABS80.lbl
    Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF
    Component: ABS 8.0 front H05 0002
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0002082
    Shop #: WSC 00788 785 00200
    VCID: 8109DBD1DB1E4C16149-5124
    2 Faults Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 2
    Fault Frequency: 161
    Reset counter: 98
    Mileage: 41074 km
    Time Indication: 0
    18265 - Load Signal
    P1857 - 000 - Error Message from ECU - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 34
    Reset counter: 98
    Mileage: 42170 km
    Time Indication: 0
    Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
    Part No: 6Q0 820 045
    Component: Klimaanlage X0850
    VCID: EADB9C7D9668AF4EA53-5124
    No fault code found.
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 K
    Component: 18 AIRBAG VW51 0P 0010
    Coding: 12600
    Shop #: WSC 00788
    VCID: 2C57DA65DC1CF17E17F-5140
    Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
    Part No: 6Q0 920 903 J
    Component: KOMBIINSTRUMENT VDO V06
    Coding: 01431
    Shop #: WSC 00000
    VCID: 387FF63518444DDE637-5140
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: 01K1 GATEWAY CAN 2S36
    Coding: 00014
    Shop #: WSC 00788
    VCID: F0EF8E15B0B4559EEB7-5140
    Address 25: Immobilizer Labels: 5J0-920-xxx-25.clb
    Component: IMMOBILIZER VDO V06
    Coding: 01431
    Shop #: WSC 00000
    WVWZZZ9NZ8Y188336 VWZ7Z0H6468542
    Address 46: Central Conv. Labels: 6Q0-959-433.lbl
    Part No: 6Q0 959 433 H
    Component: 1N Komfortgerát 0002
    Coding: 00019
    Shop #: WSC 00788
    VCID: 408F9ED54094051EDB7-4B06
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No SW: 6Q0 035 152 E HW: 6Q0 035 152 E
    Component: Radio 9NK 0004
    Revision: 00001000 Serial number: VWZ4Z4GD270903
    Coding: 0020202
    VCID: 2C57DA658C1CF17E17F-5140
    Address 01: DTCs cleared
    Address 03: DTCs cleared
    Address 08: DTCs cleared
    Address 15: DTCs cleared
    Address 17: DTCs cleared
    Address 19: DTCs cleared
    Address 25: DTCs cleared
    Address 46: DTCs cleared
    Address 56: DTCs cleared
  2. Re: POLO Timing Issue 1.2 6v BBM
    Hi did you get this sorted - I have exactly the same fault codes on the same engine. I was going to replace the camshaft position sensor but couldn't see how this would effect the ABS ecu fault?
  3. Re: POLO Timing Issue 1.2 6v BBM
    131 Post(s)
    1976 Post(s)
    The engine and ABS ECU';s talk to each other as part of the Electronic Performance Control system and an engine power delivery problem can generate ABS codes like that. However, the G40 sensor is not normally the problem, on this engine it is often a sign there are problems in the cam chain system.
  4. Re: POLO Timing Issue 1.2 6v BBM
    Mar 2014
    suffolk
    Unfortunately when looking at the vehicle we were not given the full story. The car had already been many places including main dealer for the fault so we walked away from it.
    From memory the scans kept throwing up random codes so in the end we suspect wiring/ecu fault but suggesting taking the vehicle to an auto electrician.
  5. Re: POLO Timing Issue 1.2 6v BBM
    Hi did you solve this problem - I have the same issue. I've done the timing but was thinking about the ECU next?
  6. Re: POLO Timing Issue 1.2 6v BBM
    Jul 2007
    glasgow
    35 Post(s)
    have you replaced the new sensor with another new one ?
    New can be faulty .............................................. is it a genuine sensor ?
  7. Re: POLO Timing Issue 1.2 6v BBM
    131 Post(s)
    1976 Post(s)
    I have a bit of a rule on ECU's, "it's never the ECU......except when it is...."
  1. 1.2 BBM Cylinder 2 no compression
    By Swearingmuffin in forum Polo - Derby - Lupo - Fox
    Last Post: 18-03-2014, 12:42 AM
  2. Please Help Misfire In BBM Engine
    By A4 Lad in forum Fabia
    Last Post: 04-10-2012, 07:27 PM
  3. Important 1.2 6v BBM petrol high mileage
    By SuperCharger28 in forum Polo - Derby - Lupo - Fox
    Last Post: 17-08-2012, 07:06 PM
  4. V6 Misfire Timing chain Issue..
    By jockmonkey in forum Touran - Sharan - Caravelle
    Last Post: 20-12-2010, 03:40 PM
  5. Timing Issue - Help
    By EMM123456 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 07-03-2009, 06:56 PM
