Thread: Sharan 2008 - Clutch problem
  1. Sharan 2008 - Clutch problem
    Mar 2014
    Norge
    I have a Sharan 2008 model with a strange problem with the clutch.
    Some times when I shift gear under acceleration, the clutch appears as an on/off switch. I try to release the clutch smooth out but the car acts as a rabbit jumping forward. I can prevent this by let the engine fall down almost too idle rpm and then release the clutch extremely soft/carefully. When doing this in uphill I lose almost all speed……
    Two times I also had the problem that when I pressed the clutch pedal down the clutch didn’t release (disconnected the gear box) so the car still running (one time in reverse and one time driving forward). I had to press the breaks to stop the car and result was of cause that the engine topped also. By this I can’t remember if I just started the engine again or released the clutch pedal and then pressed it down before starting the engine. I was a bit stressed……. of it.
    Is it in the clutch, or can is it the clutch mechanism?
    My big problem this is not continues but appears sometimes. Therefore I haven’t been able to demonstrate it for the mechanical staff at the VW service center.
  2. Re: Sharan 2008 - Clutch problem
    Mar 2014
    Norge
    The problem is found.
    The workshop found that there was a slat from the clutch plate had broken off and was between it and the flywheel.
    1 1 0
  1. 05 sharan 130bhp clutch/slave cylinder problem?
    By gbdundee in forum Touran - Sharan - Caravelle
    Last Post: 15-03-2014, 09:23 PM
  2. 2008 sharan changing rear pads
    By amcjam2468 in forum Touran - Sharan - Caravelle
    Last Post: 11-11-2012, 01:36 PM
  3. 2008 tdi 105 golf clutch help
    By Rudidudi in forum Golf MK5 - 2004 - 2009
    Last Post: 12-09-2012, 12:30 PM
  4. Hi New Here - 2008 Sharan TDi aircon
    By lisani2003 in forum Touran - Sharan - Caravelle
    Last Post: 12-06-2012, 05:48 PM
  5. New Sharan UK Launch Date 2007 or 2008
    By Hog in forum Touran - Sharan - Caravelle
    Last Post: 15-07-2007, 09:34 PM
