Thread: Can bus issue.
  1. Can bus issue gone but now tailgate issue!
    Please, i could use some help / advise i have with a can bus issue!
    Car is B5.5 03 plate. 130PD. AWX.
    VCDS tells me that the can bus is operating on single wire.
    Can anyone tell me what the can bus is connected to?
    I know it goes to the CCM, and doors and cluster but what else? Can gateway shows no fault.
    My CCM is dry as is the wiring. I had some issues with a couple of lightly corroded pins in one of the multi plugs in the N.S kickwell but no other faults that im aware of and everything in the car works as it should.
    The only other issue im having is a fault related to the climatronic, VCDS shows a 0038 or 21A referance voltage to low, im looking into this aswel.
    Rest of the car is faultless and it would be nice to sort out these 2 little niggles.
  2. Re: Can bus issue.
    Norfolk
    Quote Originally Posted by Gary03 View Post
    It is what it says. You have a disconnected CAN wire. Probably at or near the ccm. B5 passat has very little CAN wiring. I would search for dirty connections. They must be perfect for CAN to work properly. The fault may relate to the climatronic fault.
  3. Re: Can bus issue.
    Thanks for the feedback Martin, Il take another good look around.
  4. Re: Can bus issue gone, but now tailgate problem!
    Well I seem to have sorted my CAN bus wire issue, VCDS says no fault found now and it wont come back!
    But does anyone know why I can only un lock my tailgate using the tailgate unlock button on the remote now?
    It used to unlock when the doors unlocked with one press.
    The unlock button for the tailgate on the drivers door dosn't seem to do anything now either.
    Seems to have been like this ever since I removed my CCM a couple of weeks ago.
    VCDS shows no faults!
  5. Re: Can bus issue gone, but now tailgate problem!
    Norfolk
    It may well be a bad connection at or near the ccm. Isn't this fun
  6. Re: Can bus issue gone, but now tailgate problem!
    Quote Originally Posted by martin1810 View Post
    YEP!!
    I reckon il be removing the front pas seat and CCM again then!
    Its no big deal I suppose but I like things to work properly no matter how trivial.
    Think Il be waiting unti it warms up abit though. Thanks again Martin
  7. Re: Can bus issue gone, but now tailgate problem!
    YEP!!
    Sorted my tailgate locking issue!
    Turned out to be the key lock on the tailgate itself was in the wrong position, I didn't know about that little "trick".
    It was altered from the normal position by me whilst sorting the dead motor issue I had about 3 weeks ago.
    I also changed the selective unlocking with VCDS whilst I was at it so everything Is now normal again. One press and the whole car unlocks!
    The only small issue I have now is the low voltage to my Climatronic making the display flash. Easily sorted I reckon in a couple of hours.
  1. Please Help Alhambra no power fuse 19 pos CAN BUS issue
    By Dozz in forum Alhambra
    Last Post: 02-07-2010, 09:11 PM
  2. GOLF V BUS-CAN or BUS R-LADDER ???
    By DSGFAN in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2009, 12:26 AM
  3. Important CAN bus or non CAN bus???
    By linners in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-08-2008, 10:58 AM
  4. Please Help Golf VS Bus...Bus wins
    By LSDJ in forum Golf MK4 - 1999 - 2004
    Last Post: 02-06-2008, 06:32 PM
  5. Attention obd11 or can-bus
    By drodders in forum Touran - Sharan - Caravelle
    Last Post: 13-05-2008, 10:34 PM
