Thread: 'Sticky' throttle pedal
  1. 'Sticky' throttle pedal
    Mar 2014
    Ballina, Mayo, Ireland
    Hi All,
    My first post here but thought I'd share my info. I was experiencing high revs during gear changes and, having done a search here, thought maybe it was the clutch pedal switch but the symptoms were not exactly the same.
    My cruise control worked fine and my problem only became evident after driving for about an hour. It may be that it was cabin temperature related. Anyway, I managed to get it to the dealer while it was happening. The technician verified the symptoms and a new throttle pedal was installed. I could see during the test drive that the pedal was slow to return to normal position when the tech's foot was lifted off the pedal.
    Have driven it for a week now (several 3 hour journeys) without any problem. I did not see this particular problem on the forum so thought I'd share.
  2. Re: 'Sticky' throttle pedal
    Apr 2013
    Stirling
    11 Post(s)
    Thanks for sharing... Glad it's sorted now! Quite a scary thought really... Never heard of this issue brfore!
  3. Re: 'Sticky' throttle pedal
    Mar 2014
    Quote Originally Posted by AlyM View Post
    Yes, scary indeed. I was imagining it sticking down permanently. I only have the car a few months (A6 C6 2010 S-Line) so it was repaired under the used car warranty.
  4. Re: 'Sticky' throttle pedal
    Apr 2013
    Stirling
    11 Post(s)
    Sounds like you were quite lucky then... Wonder how much it would've cost!?
  5. Re: 'Sticky' throttle pedal
    Mar 2014
    Ahhh .... an even scarier thought.
  1. VW touran Sticky throttle
    By ProDave in forum Touran - Sharan - Caravelle
    Last Post: 26-01-2014, 05:08 PM
  2. Question Mk5 Clucth Pedal sticky!!!
    By onzarob in forum Golf MK5 - 2004 - 2009
    Last Post: 02-09-2011, 10:55 PM
  3. Throttle pedal....
    By Jamiem in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-02-2011, 05:23 PM
  4. Question throttle pedal fault
    By richhall in forum 80 - 90
    Last Post: 20-11-2010, 02:20 PM
  5. sticky throttle??
    By wheelywonderful in forum TT - 8N Forum - 1998 - 2006
    Last Post: 04-10-2009, 03:52 PM
