Thread: Slow clutch pedal returning
  1. Slow clutch pedal returning
    Jan 2014
    Cardiff, Wales
    Hey all, I have a 2004 2.0 140 tdi bkd with an annoying problem....my clutch pedal is slow to return, giving a second or two delay...also, sometimes the clutch pedal seems soft! I looked under the clutch and noticed theres a raw plug in the pedal? No clue what its forgrrrr....I love this car so much...the coolest 19 year olds car ever made, but the clutch is driving me nuts...any ideas? Cheers all
  2. Re: Slow clutch pedal returning
    46 Post(s)
    Check the brake fluid level under the bonnet, most cars run off the same reservoir for the clutch and brakes.
  3. Re: Slow clutch pedal returning
    Jan 2014
    Cardiff, Wales
    hey a6 chris,
    checked level and bled clutch from slave cylinde
    r but still the same...im thinkin maybe faulty slave cylinder??
    cheers
  4. Re: Slow clutch pedal returning
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    There is also a possibility of the Release Bearing sticking on the Input shaft sleeve. But check Pedal area first, including the 'over-centre' spring.
    Alan.
    VW T6 150 DSG Camper £££
  5. Re: Slow clutch pedal returning
    Jan 2014
    Cardiff, Wales
    Quote Originally Posted by Alan02 View Post
    Hi Alan thanks for the suggestions! is there any way to check the over centre spring? cheers
  6. Re: Slow clutch pedal returning
    Nov 2008
    20 Post(s)
    Sorry for the delay! You may have this sussed by now.....but...have a look up by pedals and you will see a spring, most probably on a pushrod. That spring is the over centre spring which takes the weight off the pedal when depressed. It should be intact.
    Alan.
  1. Worsening Mechanical Noise from Clutch Housing When Depressing Clutch Pedal.
    By uncleron in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-07-2013, 08:37 PM
  2. Clutch pedal needing adjusted or Clutch on way out?
    By rossvwp4m in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-04-2010, 05:57 PM
  3. Clutch pedal Help please
    By Gomar in forum Golf MK4 - 1999 - 2004
    Last Post: 17-01-2009, 02:00 PM
  4. clutch pedal
    By frank99jc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-07-2008, 09:47 AM
  5. CLutch pedal
    By sonic in forum Polo - Derby - Lupo - Fox
    Last Post: 11-03-2008, 08:26 AM
