Thread: VCDS Required for a DPF sensor adaptation in London
Results 1 to 10 of 16
  1. VCDS Required for a DPF sensor adaptation in London
    Mar 2014
    London
    Hi folks need help with the DPF sensor adaptation for my VW golf MK 6 . I have already dished out a lot for the diagnostics and repairs as I had the dreaded engine management light coming up frequently.
    Garage thinks its a faulty DPF sensor which I have purchased but they want 50 quid to fit ?? Strange for a 15 mins job ( Even i dont get that!)
    PM me or reply to this post if you are able to help . Can drive as far as kent if required.
    Thanks in advance chaps
  2. Re: VCDS Required for a DPF sensor adaptation in London
    134 Post(s)
    2001 Post(s)
    That's very reasonable for what is a half hour job for fitting and setting up at London rates.
  3. Re: VCDS Required for a DPF sensor adaptation in London
    Feb 2014
    Sorry are you saying your going to fit it and you want someone with vcds to clear the fault code?
    Using Tapatalk
  4. Re: VCDS Required for a DPF sensor adaptation in London
    Mar 2014
    London
    Quote Originally Posted by gtime View Post
    Yes was planning to it's easily accessible I think saw it as soon as I opened bonnet
  5. Re: VCDS Required for a DPF sensor adaptation in London
    Mar 2014
    London
    You very right but I already shelled out 220 quid to this garage. I am just stressed with the car should have stuck to my honda civic
  6. Re: VCDS Required for a DPF sensor adaptation in London
    Feb 2014
    I am in Weybridge Kt13, but go to London once a week for work. Travel by tube. I can reseat fault codes but that's about it.
    Using Tapatalk
  7. Re: VCDS Required for a DPF sensor adaptation in London
    134 Post(s)
    2001 Post(s)
    Just be thankful you don't own a 4.2 Q7 TDI, I have got to fit two new DPF pressure sensors to one next week, about the same price each as yours for the part but to change them you have to drop the engine and gearbox down......
  8. Re: VCDS Required for a DPF sensor adaptation in London
    Mar 2014
    London
    Just be thank full you don't own a 4.2 Q7 TDI, I have got to fit two new DPF pressure sensors to one next week, about the same price each as yours for the part but to change them you have to drop the engine and gearbox down......
    Oh dear! That definitely will make me bankrupt learnt my lesson with VW's / Audi they are really highly Maintenance
  9. Re: VCDS Required for a DPF sensor adaptation in London
    134 Post(s)
    2001 Post(s)
    ALL modern cars, especially ones fitted with Herr Diesels awful invention, are a maintenance problem and this is set to get MUCH MUCH worse in the next few years. EU5 may be a pain but God help all oil burner owners when EU 6.2 is rolled out....
  10. Re: VCDS Required for a DPF sensor adaptation in London
    Feb 2013
    Gloucester
    57 Post(s)
    What's EU 6.2 going to involve?
  1. DPF pressure sensor or just a blocked DPF
    By dan2485 in forum VCDS - General Questions
    Last Post: 30-04-2018, 09:24 AM
  2. vcds required for software downgrade RNS-E Essex/east london
    By rojdag in forum VCDS - Help Requests
    Last Post: 10-04-2013, 10:36 AM
  3. VCDS help in SE London
    By mya4audi in forum VCDS - Help Requests
    Last Post: 23-07-2012, 03:00 AM
  4. Please Help A4 B8 DPF Fault P2452 No or Incorrect Basic Setting / Adaptation - Help Required
    By Mickyd98 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-04-2012, 08:26 PM
  5. VW Golf 1.9td (1999) Engine -AHF Required Adaptation Codes
    By Grandad Dave in forum Golf MK3 - 1993 - 1999
    Last Post: 29-07-2010, 05:48 AM
