Thread: Auto lights
Results 11 to 20 of 22
  1. Re: Auto lights
    Jan 2013
    Scotland
    11 Post(s)
    I didn’t quite have the same experience. In auto mode this morning when it was bright out, only the auto wording was illuminated but my DRLS were physically on. When I put it to the green bit (i.e. side lights) , the green bit lit up too, nothing happened to my physical car lights as the DRL lights double up as side lights. When I I put it to the red dipped icon, it lit up and my physical dipped lights came on which are of course my HID lights. Last night when I checked performed this task, the swithch had all icons and wording illumated whilst in automode, beucase it was dark out and all were required to be on. This all seems to check out with what my manual says each lights does.
    Audi A6 3.0 BiTDI Black Edition
  2. Re: Auto lights
    Oct 2009
    Birtley
    Do you have SatNav? That is the easiest way for me to tell if my headlights are on as I have night colours set on the SatNav. This is the only way I have found to show the current light status when in auto.
    Audi A4 2.0TDI Quattro 177PS Black Edition (B8.5) in Brilliant Black, B&O sound system, MMI 3G+ satnav, Parking System plus, Interior LEDs, Privacy Windows
  3. Re: Auto lights
    Jul 2012
    United Kingdom
    Quote Originally Posted by gdallas View Post
    It sounds like we have similar functionality during the day when in auto. So when DRL are on and nothing else only auto lights up. The green light comes only when headlights are on even though the DRL are already on. The difference seems to be when moving knob to green light icon. My DRL switch to dipped mode as if i was indicating. Could be different during the night
  4. Re: Auto lights
    Jan 2013
    Scotland
    11 Post(s)
    when you say "My DRL switch to dipped mode as if i was indicating." dipped to me means the HID lights, do you have HID? are your DRL LEDs or Halogen?
  5. Re: Auto lights
    Apr 2012
    Somerset
    When in auto mode, if the green light comes on then the headlights are on. If the green light isn't on then they're not. You can't have sidelights on with automatic headlights, only way to use sidelights is to select them manually. The green light is a bit of a bugger to see when it's light, but just put your hand over it to shade the light and then it's easy enough to see.
    DRL's will switch to dipped as soon as you select sidelights or headlights, it's just it's less obvious them being dipped with headlights. This is because DRL's are designed to be brighter than sidelights, but they use the same lights. Only difference between DRL's and sidelights is with sidelights the bulbs are dimmed at the front and it turns on the rear lights.
    Now: 2016 Passat SE Business Estate | V&C Pack | AID | DLA | TPMS
    Old: 2012 A4 Avant SE Technik | TDIe | Tech Pack High | Foldy Mirrors | TPMS | Heated Seats | Auto Hold
  6. Re: Auto lights
    Jan 2013
    Scotland
    11 Post(s)
    Some confusion here I think. Headlight is the entire cluster of lights not one particular light. My DRLs are exactly the same LED strip as used for my “sidelight” function. The only difference being that when in DRL mode or auto during the day, they are significantly brighter than if they were placed manually in the green “sidelight” position during the day. In the green sidelight manual position, normal HID dipped lights DO NOT come on as yawgumbo says. They will only come on when the switch is manually moved to the red dipped position at which point my DRL/sidelights are in sidelight mode, not DRL; or if it was dark and in automode.
  7. Re: Auto lights
    #17
    Jul 2012
    United Kingdom
    Quote Originally Posted by YawnGumbo View Post
    I'm referring to headlights as the HIDs (main headlights) and the DRL as the LED strips.
    So by dipped I mean the DRL (I'm talking about the LED strip here if DRL is only when they're bright) are dipped when switching to the green “sidelight” position. The HIDs do not come on at all when in this position. No dipped mode for these lights.
    The green light only comes on in auto mode when the HIDs are on. This signifies the Main headlights (Xenons) are on. They are not related to whether the DRLs are on or not. If the HIDs are on, the red light is still off when in auto mode.
    When switchin to the 'sidelight' position, then the green light comes on and the red light also comes on. When switching to the 'red' lights position, then the HIDs also turn on along with 'sidelights'. So the green and red light are both lit up.
  8. Re: Auto lights
    #18
    Jul 2012
    United Kingdom
    So checked the lights in the evening too so to conclude (I may not be exact on with terminoligy)
    - During day
    --When in Auto Mode the Auto light is on on the light panel
    --When in Auto Mode and DRL are enabled in MMI, no other indicator light (apart from 'Auto' light) is enabled on the light panel
    --When in Auto Mode and the Xenons are on due to weather conditions (e.g. rain), the green indicator light on the panel is lit. This is the only light that is lit in addition to the auto light.
    - During night (when it's dark)
    --When in Auto mode, all the lights on the panel are lit (as below image shows. I've attached the same image as gdallas did which i believe is from his/her car). This also means the Xenons are on.
    So when the green indicator light is enabled (during day) or all the lights are enabled (during night), this means the xenons (main headlights) are also enabled. Hopefully this answers the query around knowing when the Xenons are on.
    Attachment 23911
  9. Re: Auto lights
    #19
    Apr 2012
    Somerset
    I didn't say the headlights would come on when the switch was moved to the green light option. I said when the green light is lit when you leave the switch in auto then this means the headlights are on. This really isn't as difficult as you think
  10. Re: Auto lights
    #20
    Jan 2013
    Scotland
    11 Post(s)
    I'm not finding this difficult... I'm now perfectly clear how my headlights work.
    Sent from my Nexus 5 using Tapatalk
  1. Auto Lights
    By Dave B in forum Golf MK6 - 2009 - 2013
    Last Post: 02-12-2012, 11:35 PM
  2. Please Help Enabling Coming Home lights in VCDS (no auto lights fitted)
    By patomlin76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-07-2011, 09:42 PM
  3. Auto-Dim Mirror/Auto Lights/Auto Wipers Retrofit
    By mercedeslimos in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-07-2011, 03:50 PM
  4. Auto lights
    By Tony2 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-02-2010, 10:19 PM
  5. Fog lights on with auto lights setting?!
    By Edjog in forum Golf MK6 - 2009 - 2013
    Last Post: 03-11-2009, 12:53 AM
