Thread: Horrible noise on full lock while manoeuvring
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
  1. Horrible noise on full lock while manoeuvring
    Mar 2011
    Clitheroe, England
    11 Post(s)
    So today my car has developed yet another noise. While manoeuvring at low speed with the steering wheel turned at full lock or close to it, say when pulli g in or out of a parking space, I get a bad grinding/rumbling noise, but just when I'm not pressing the accelerator, when I do use a little accelerator, the noise disappears.
    Could this be a lack of power steering fluid, or is this likely to be something else? Hopefully a common thing that's an easy fix lol.
    The Only Way Is A6!
  2. Re: Horrible noise on full lock while manoeuvring
    May 2012
    essex
    My old s4 used to do exactly that same thing when the power steering fluid was low.
    Check the level, even if its not at the minimum mark but down a bit top it up and hopefully be sorted
    2007 3.0 tdi le mans
    Hybrid turbo decat miltek etc
    330-350 bhp
    450-500lbsft
    2007 3.0 tdi le mans : Hybrid turbo decat : miltek etc : 330-350 bhp : 450-500lbsft
    Visibility pack. Adaptive xenon, Privacy glass. Bose surround. Dvd nav. Comms pack, led plate lights.
    Miltek, custom map,hybrid turbo, decat improved airflow to intercoolers.
  3. Re: Horrible noise on full lock while manoeuvring
    Pembrokeshire
    22 Post(s)
    or the alternator pulley is seized up. does the tensioner jump about much
  4. Re: Horrible noise on full lock while manoeuvring
    Mar 2011
    Clitheroe, England
    11 Post(s)
    I'll check the pas fluid this morning & hopefully find it to be below minimum.
    Not sure how to check if the tensioner jumps about, how do I check? Then I can report back once I know.
    Sent from my GT-I9300 using Tapatalk
    The Only Way Is A6!
  5. Re: Horrible noise on full lock while manoeuvring
    Nov 2012
    Somerset UK
    Also check it's the correct PAS fluid, on my car it has to be green hydraulic fluid and some numpty had previously put in standard red fluid making a brown mess which will affect seals.
  6. Re: Horrible noise on full lock while manoeuvring
    Pembrokeshire
    22 Post(s)
    blimey, first its the polar bears and now its the seals that face extinction, from pas fluid of all things. ???
    0 2 0
  7. Re: Horrible noise on full lock while manoeuvring
    Mar 2011
    Clitheroe, England
    11 Post(s)
    I've checked the pas fluid level as best I can, the design of the dipstick thing under the lid doesn't make it easy to accurately measure it, but it seems to be a little over maximum. The colour is reddish brown.
    I'll try to link a voice recorder file so you can hear the noise. Sounds like a tractor & it does it on full lock both left and right.
    Dropbox - Voice 008.m4a
    The Only Way Is A6!
  8. Re: Horrible noise on full lock while manoeuvring
    Jan 2011
    Stafford, UK
    Quote Originally Posted by Brycie View Post
    When did you last change the PAS fluid ?
    It should be clear greenish colour.
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  9. Re: Horrible noise on full lock while manoeuvring
    Mar 2011
    Clitheroe, England
    11 Post(s)
    The car had it's service not all that long ago, but I'd need to check if pas fluid change was done as part of the service.
    The Only Way Is A6!
  10. Re: Horrible noise on full lock while manoeuvring
    Feb 2009
    Glasgow UK
    I'd say that it was unlikely that the PAS fluid has ever been changed as part of a service, unless requested........The dealers don't even change air filters for at least 40k!!
    I'd certainly check Paul, but my moneys on NO
    Hope to hear all is well soon
    1 1 0
  1. Rumbling noise on full lock
    By Guest 2 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-07-2010, 03:45 PM
  2. Full lock steering noise
    By fat controller in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-06-2010, 10:09 PM
  3. Question Audi Coupe 1995 2.0E - Clunking sound when steering on full lock and Manoeuvring
    By Jonnovision in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 23-02-2010, 10:58 PM
  4. Clicking noise on full lock?
    By bushid0 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-05-2008, 12:18 AM
  5. Noise on full lock
    By Spiceman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-04-2008, 03:03 PM
