Thread: New car... rear end knock
Results 1 to 10 of 15
  1. New car... rear end knock
    Nov 2013
    Hi All,
    Collected our new A6 S-line yesterday and got the VIP treatment from the dealer (no goodies though). After thoroughly inspecting the car and having everything well explained by the salesman we drove away happy. A few miles up the road I thought I heard a rear end knock as I drove over a slightly bumpy section of road but wasn't sure. Then I heard it again and then again. Sounded like something loose in the boot or the exhaust knocking the underside of the car. Got home and checked that the spare wheel was secure and just in case I padded out the jack. As expected we have been out and about in the car again today and there is still definitely a noticeable rear end knock when I drive over a repair in the road or a bumpy section. I will of course be on the phone to the dealer tomorrow but just wondered if anyone else has experienced this or could offer an explanation.
    I also have a slight intermittent vibration coming from the drivers door or the door pillar.
    Apart from that the car is superb.
    Thanks,
    Janner
  2. Re: New car... rear end knock !!
    Apr 2009
    Surrey
    182 Post(s)
    Quote Originally Posted by JannerAudi View Post
    Hi All,
    Thanks,
    Janner
    Immediate thought is whether they have removed all the chocks from the suspension, also check the tyre pressures as these are set very high during shipping and sometimes they forget to set them to the correct pressure. On my previous A6 3 out 4 tyres were Ok and the fourth was at 50psi
  3. Re: New car... rear end knock !!
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    Poor pdi, It's the yellow bumpstop not been reseated into the damper shroud after removing transport chocks. Common problem. Can result in damage to suspension if you're unlucky. Kick up a fuss.
    Over to you Mr Wuffles!
  4. Re: New car... rear end knock !!
    Sep 2013
    I had this. It was some shielding under the rear suspension that was loose. It sounds like the jack is loose in the boot.
    My local dealer fixed it for me.
  5. Re: New car... rear end knock !!
    Wuffles Guest
    Thread resurrected. Go for gold at the dealers.
  6. Re: New car... rear end knock !!
    Nov 2013
    Whippy53 you were right. The problem was the incorrect (or not at all) re-seating of the yellow bump stops into the damper shroud.
    At the dealers I made sure I was in attendance from the moment our car was lifted on the car ramp and it was clear that the bump stops were loose, free to slide up and down the damper shaft and not seated in the damper shroud. Master technician re-seated the bump stops and has assured me that there is no damage to the suspension. I have requested that the matter is logged and that I have something in writing noting the incident and the remedial work carried out. The dealership have been very apologetic, offered a goodwill gesture and we have agreed on an Audi S-Line fleece for myself and my wife. No knocks noticed on the way home so hopefully we can now enjoy our new car.
  7. Re: New car... rear end knock !!
    Wuffles Guest
    I'd already seen this thread, in fact I'd commented. What was the goodwill gesture? Or was it the coats?
  8. Re: New car... rear end knock !!
    Nov 2013
    The goodwill gesture we settled on was the coats.
    I was aware you had posted on this thread. The link on the similar thread was to take people to where I had written the outcome.
  9. Re: New car... rear end knock !!
    Jan 2013
    114 Post(s)
    Good, so glad its sorted now. I wonder if you would impart which dealer was responsible? Enjoy the fleeces, probably the first time they've been fleeced themselves!
  10. Re: New car... rear end knock !!
    Nov 2013
    Quote Originally Posted by Whippy53 View Post
    No I won't reveal the dealer as they resolved the problem very quickly, were very apologetic.... and I have to go back there !!
    Probably won't need the fleeces now until next winter !!
  1. knock knock bang bang front end
    By billyspiller in forum Golf MK4 - 1999 - 2004
    Last Post: 09-09-2010, 05:24 PM
  2. Front end knock???
    By gticorsa in forum Golf MK3 - 1993 - 1999
    Last Post: 07-09-2010, 10:37 AM
  3. Question knock for the back end
    By FLENG2008 in forum Golf MK4 - 1999 - 2004
    Last Post: 06-08-2009, 03:21 PM
  4. knock on back end
    By damianwilshaw20 in forum Bora - 1998 - 2005
    Last Post: 22-07-2009, 10:26 AM
  5. Question creek on front/back end + knock on back end
    Last Post: 25-03-2009, 08:38 PM
