Thread: Golf mk4 1.6SE timing belt
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. Question Golf mk4 1.6SE timing belt
    angel18082005 Guest
    Anyone know offhand how often a timing belt should be changed on a Golk Mk4 S reg 1.6SE ? Its done 92,000 miles....
    Sarah
  2. Re: Golf mk4 1.6SE timing belt
    I think it should be every 60K miles of 4 years? but don't quote me on that, i'm sure someone will along soon to but it right.
  3. Re: Golf mk4 1.6SE timing belt
    Nov 2008
    Beverley East Yorkshire
    Yeah its every 60k but i would do it early as they make a mess when they go! ask me how I know sometime.
    make sure you change the tentioners and water pump too while your at it.
    Unauthorised commercial link removed as per forum rules
  4. Re: Golf mk4 1.6SE timing belt
    you say every 60k mile or 4 years. mine is golf 1.4 1999 model and its done 25k, when would you recommend mine getting changed, thanks
  5. Re: Golf mk4 1.6SE timing belt
    Pembrokeshire
    22 Post(s)
    er, if its still on the original belt, then i would change it tomorrow morning. even with a mere 25k on the clock, the belt is now 10 years old. they perish/degrade over time, and yours is currently on borrowed time.
  6. Re: Golf mk4 1.6SE timing belt
    ok???!! your scaring me there, lol. does that mean i have to change the water pump and all the other things that go with it it? what are the signs of the timing belt on its way? thanks
  7. Re: Golf mk4 1.6SE timing belt
    Nov 2008
    You do NOT get a warning its just bang rattle rattle rattle then a big £1000+ bill
    and I would change tentioners not sure the 1.4 needs a waterpump though.
  8. Re: Golf mk4 1.6SE timing belt
    thanks for the reply, and sory for hijacking your post angel
    any idea on how much it would cost?
    for a car this old with 25k on the clock, is there anything else that needs to be clanged. thanks
  9. Re: Golf mk4 1.6SE timing belt
    Feb 2009
    just wanted to say thanks for this info, mine last got changed at 88,000 and I've just hit 130,000 but it was a little over 4 years ago (aug 08) so im going to book her in soon, due a yearly service 22 feb anyway.
    Out of interest - how many miles do you think these cars will do before they give up the ghost? assuming they are properly serviced. Mine is an S Reg (1999?) 1.6SE (although says SR on the engine so maybe its an SR?!) and it seems good at the moment.
  10. Re: Golf mk4 1.6SE timing belt
    133 Post(s)
    1986 Post(s)
    The timing belt on the SR engine (either an AKL or AKH) should be changed every 5 years or 80K miles. The car has a very unreliable version of the 02K box called a DUU normally and these are extremely prone to throwing rivets out of the differential which punch holes through the casing. The engines have an unpleasant habit of losing oil control on the rings and head gaskets are a common problem as are failed ECU’s.
  1. timing belt
    By vdubpolo in forum Chat - Anything with wheels
    Last Post: 02-09-2007, 11:59 PM
  2. Golf TDI 150 timing belt change
    By GKMVW in forum Golf MK4 - 1999 - 2004
    Last Post: 22-03-2007, 11:10 PM
  3. Mk4 Golf (ASZ - 130 bhp TDI) Timing Belt Issues
    By gavbarlow in forum Golf MK4 - 1999 - 2004
    Last Post: 05-02-2007, 01:12 PM
  4. Cam belt timing belt tip , general
    By Conradvw in forum Archive posts
    Last Post: 11-01-2007, 04:29 PM
  5. timing belt/ cam belt change
    By jonoallen in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-11-2006, 01:24 PM
