Thread: S4 springs
  1. S4 springs
    Aug 2007
    Can anyone tell me if the springs from an S4 avant 1999 will fit on a 2.5tdi 2wd 1998?
    Or could anyone point me in the direction of a site where i could find out the rates lengths and diameters of springs for the S4 and 2.5 tdi?
    Stephen
  2. Re: S4 springs
    london/ UK
    The fronts may fit but the rears wont as the S4 is Quattro ! They are the similar diameter but they shorter. Also, check what suspension set up you have on your car, if the shocks are red (Boge OEM air ), then you have sport lowered suspension ,but if they black (Boge oil filled-OEM) then you have standard set up. I think the S4 has red shocks as well and matched short springs and beefier anti roll bars front and black.
  3. Re: S4 springs
    Aug 2007
    Adam,
    From your reply does that mean the S4 and the A4 sport set up use the same ride height but possibly stiffer springs?
    also do you happen to know the difference in the length at the rear between the 2 & 4 wd?
    thanks again
    Stephen
  1. jamex springs
    By dizzydubbersmrs in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-05-2008, 12:30 AM
  2. Lowering Springs ??
    By craigbeal in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-09-2007, 08:43 AM
  3. got any springs?? B5 A4 TDI 97
    By lostplanet in forum Audi A4 - Archive Topics
    Last Post: 31-08-2007, 08:32 PM
  4. coil springs
    By panther in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-05-2007, 06:10 PM
  5. A4 springs
    By Maddog16 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-05-2007, 01:44 PM
