Thread: Car won't go over 1500 rpm in 1st gear!
Results 1 to 10 of 19
  1. Exclamation Car won't go over 1500 rpm in 1st gear!
    Mar 2007
    Greater Manchester
    Over the last few days there are occasions when the car won't go over 1500rpm when setting off in 1st gear.
    I've noticed it tends to happen on relatively cold start when i first get moving but it has happened part way through a journey aswell. I try to put my foot down but the needle dosn't move nor is there any power to the wheels (don't think I can hear the engine revs increasing either). I slip it into 2nd and all is ok. Even if I use 1st gear immediately after, it works fine.
    Havn't had a chance to plug VAG COM in yet.
    Must also point out that the weekend before last (2nd Sept) I was part way through fitting cruise control myself (unfinished project). There is a certain connection that I have left unplugged (was previously plugged in). It is a black plug and in the Control Box under the wiper motor. I believ this shouldn't affect it as it's only used for CruiseControl (I believe). If this was the problem then it wouldn't be intermittent would it. Would either work or not at all.
    Any pointers folks?
    Thanks in advance
    2001 Bora TDi PD 115 (AJM)
  2. Re: Car won't go over 1500 rpm in 1st gear!
    Jun 2007
    Bristol
    thats a weird one m8
    i dont what to suggest , maybe put it back how it was before the cruise , and test it then ?
    MK5 Golf TDI 2.0ltr GT Sport in Black
  3. Re: Car won't go over 1500 rpm in 1st gear!
    Mar 2007
    Greater Manchester
    Quote Originally Posted by cbrpaul View Post
    unos problemos
    The reason I didn't reconnect it at the time is because the I pushed the plug through a plastic grid that holds it. So now it's sitting somwhere behind the dash, near the instrument cluster (behind that). It's very inaccessible but I'm going to give it another try this weekend and complete the 'project'.
  4. Re: Car won't go over 1500 rpm in 1st gear!
    Coventry
    I can't wait to read the How To.
  5. Re: Car won't go over 1500 rpm in 1st gear!
    Aug 2007
    Northern Ireland
    Imagine my surprise when I pulled up at the front of my house tonight after arriving home with my new 52 plate GT TDi to find an extra "gadget" on the headlamp stalk.... cruise control! yep, never noticed it at the garage, and it wasn't advertised as having it so guess I wont have to bother with THAT mod
    Loofer - VAG-COM is the way forward!
    Pete
  6. Re: Car won't go over 1500 rpm in 1st gear!
    Dec 2006
    Quote Originally Posted by mobitune View Post
    Pete
    LOL!!
    RickT
  7. Re: Car won't go over 1500 rpm in 1st gear!
    Mar 2007
    Greater Manchester
    Quote Originally Posted by GOLFMK5GTTDI View Post
    'How To' what?? Stop your car from going over 1250rpm in 1st Gear?
    In theory fitting cruise control is straight forward.
    It did it again today, only after starting the car up, it wouldn't go over 1250 rpm. Pressed acc but no power or noise/from the engine.
    VAG COM it is tonight.
  8. Re: Car won't go over 1500 rpm in 1st gear!
    Jun 2007
    Bristol
    pop down to Bristol loofer , we will get it on Vagcom m8
  9. Re: Car won't go over 1500 rpm in 1st gear!
    Apr 2007
    Hmm, could be few things, garage job definately, but no Engine management warning light, would have thought VAG code reader wouldn't be much good? but not really sure. Could it be the Fuel Pump? That's a bit of guess I'm afraid... Is it only first gear, or all gears?
  10. Re: Car won't go over 1500 rpm in 1st gear!
    Jun 2007
    Bristol
    Quote Originally Posted by Steve MK4 TDI View Post
    Steve , there was 2nd page to this thread m8
    Its all sorted now
  1. Mk 1 1500 GX Golf, engine troubles
    By rhudie in forum Archive posts
    Last Post: 12-09-2007, 11:21 PM
  2. Top gear
    By jzink in forum Touareg
    Last Post: 02-09-2007, 05:40 PM
  3. Help Please! 1st gear jumps out of gear
    By TollyTDI in forum Toledo
    Last Post: 17-06-2007, 07:50 AM
  4. Gear jumps out and non smooth gear changes
    By RIZWAN180 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-06-2007, 09:45 AM
  5. Gear box oil
    By Jay in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-02-2007, 10:25 AM
