Thread: Coolant leak possibly from plastic piece just to left of thermostat housing
  1. Coolant leak possibly from plastic piece just to left of thermostat housing
    somerset
    8 Post(s)
    Hi, my coolant leak seems to be coming from near the thermostat housing but I think it's nearer the block, as you look into the engine area, the thermostat housing is below the inlet manifold, directly to the left of the thermostat housing is a small curved piece of black plastic that has 1 bolt in it and the other end comes from the block, what is this and could it be leaking?
  2. Re: Coolant leak possibly from plastic piece just to left of thermostat housing
    somerset
    8 Post(s)
    Ok, to answer my own question, the piece I am referring to is called the "J" plug and is part number 06B103033A, not sure what it does, it is like a plug that is curved like a J and has a round diameter one end with an "O" ring that slides into the block and is held in place at the other end by 1 bolt. Apparently a common place for a coolant leak to occur. Not sure what other engines have this plug but certainly my BEX 1.8t does.
  1. Please Help Loss of power at higher revs, possibly air in fuel line? Tee piece on filter?
    By Simon Curtis in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-05-2011, 08:52 PM
  2. Piece of plastic from dipstick fell down hole!!
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-01-2011, 09:33 PM
  3. temperature sender plastic housing
    By abstractduk in forum Golf MK3 - 1993 - 1999
    Last Post: 06-04-2010, 08:31 PM
  4. Please Help Coolant Leak From Coolant\Water pump Housing
    By Chappio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 03:30 PM
  5. Please Help thermostat housing
    By michael lynskey in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-03-2009, 02:46 PM
