Thread: Ignition barrel just spins
Results 1 to 10 of 14
  1. Question Ignition barrel just spins
    Sep 2008
    Hi All,
    Got in the car this morning turned the key but the car did not start.
    The key goes into the ignition barrel no problem but when I go to turn it does not feel like its biting. It just turns in the barrel about a 3rd of the way around.
    Any idea on this?
    Mathew
  2. Re: Ignition barrel just spins
    Buckinghamshire
    You need a new barrel. The wafer pin is quite quite broken.
    Sent from my iPad using Tapatalk HD
  3. Re: Ignition barrel just spins
    Sep 2008
    I will shop about does if have to come from VW?
    Does anyone have instructions on how to do this?
  4. Re: Ignition barrel just spins
    Buckinghamshire
    You will have to get a new one from VW. Taking it out just needs the couling removing and from memory there is a retaining clip that allows the barrel to come out.
  5. Re: Ignition barrel just spins
    Sep 2008
    Do you think its the barrel or the ignition switch at the end of the barrel?
    This looks interesting
    Volkswagen ignition switch repair and diasssembly - YouTube
  6. Re: Ignition barrel just spins
    Sep 2008
    OK Just spoke with TPS and they want £110.13 + VAT just for a new barrel.
    Is there a more cost affective way of doing this?
    Will I be able to use my old keys in the car I dont want a diffrent key for the ignition
  7. Re: Ignition barrel just spins
    Sep 2008
    Ok I can get a Barrel from a Brakers for about £30. So I will try that and see what happens.
    Does anyone have instructions or a video on how to remove the existing barrel?
  8. Re: Ignition barrel just spins
    Oct 2005
  9. Re: Ignition barrel just spins
    Sep 2008
    Yep I can make this work I will get back to you all with my progress
  10. Re: Ignition barrel just spins
    Sep 2008
    Hi All,
    Ok got the wheel off and have been able to remove the ignition switch on doing so the part that had broken off fell out!!!
    So its a new barrel
    I have one problem!
    To remove the barrel you need to undo two screws that release it from the steering assembly. However they are just round no particular size or shape how the hell do I remove them??
    I have attached some pictures
    Please help
  1. Replies: 5
    Last Post: 21-03-2012, 11:33 PM
  2. Question Ignition Barrel
    By diablo2774 in forum Bora - 1998 - 2005
    Last Post: 14-04-2009, 06:34 PM
  3. T4 Ignition barrel
    By sparky james in forum The Commercial Range
    Last Post: 11-12-2008, 02:28 PM
  4. Ignition Barrel
    By Wellbelove1 in forum Golf MK2 - 1984 - 1992
    Last Post: 11-03-2008, 01:03 PM
  5. A6 ignition barrel
    By broket in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-12-2007, 03:14 PM
