Thread: Knocking noise
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. Knocking noise
    May 2012
    essex
    Car has started making a slight knocking noise from the rear end. Only noticable below 40ish and the noise is speed related in that the slower I go the slower the knock. Sounds like when a front cv is worm when on full lock. Noise isn't affected by loading on bends or throttle
    .Mileage is on 79k I can't raise all the wheels to spin them to identify.
    Whats the likely culprit?
    Prop bearing
    Prop cv
    Rear diff
    Rear cv
    2007 3.0 tdi le mans : Hybrid turbo decat : miltek etc : 330-350 bhp : 450-500lbsft
    Visibility pack. Adaptive xenon, Privacy glass. Bose surround. Dvd nav. Comms pack, led plate lights.
    Miltek, custom map,hybrid turbo, decat improved airflow to intercoolers.
  2. Re: Knocking noise
    Feb 2012
    folkestone.uk
    Hi.
    Could be prop or drive shaft cv.
    Silly but check nothing wedged underneath in the metalwork rubbing on a shaft.
    Dave
    Sent from my Windows Phone 8X by HTC using Tapatalk
  3. Re: Knocking noise
    May 2012
    essex
    Had a quick look underneath this afternoon and couldn't see anything obvious rubbing, no scrape marks anywhere either.
  4. Re: Knocking noise
    Feb 2012
    folkestone.uk
    Just an outside chance.
    Past experience not with Audi, more likely to be a driveshaft cv.
    Dave
  5. Re: Knocking noise
    Buckinghamshire
    Jack it up and wiggle the wheel, or take it to an MOT station
    Sent from my iPad using Tapatalk HD
  6. Re: Knocking noise
    May 2012
    essex
    Well found the issue, rear brake calliper hanging off and grinding inside of wheel!
    Last people to have that off was Audi to fit pad so
    Sent from my GT-I9000 using Tapatalk 2
  7. Re: Knocking noise
    Sep 2008
    mostly in the garage
    How long ago did they fit pads? The technicians name is usually on the invoice, good job the top bolt didn't come out as well... go back and complain you may get a complimentary service or something...
  8. Re: Knocking noise
    May 2012
    essex
    Was done as a cash job by one of the mechanics as got a mate who works there on sales so no official comeback.
    Scared as to what would of happened if had to emergency stop on a motorway with my boy in the car.
  9. Re: Knocking noise
    May 2012
    essex
    HELP.
    next problem.
    Got a new bolt, realigned caliper. This needed gentle persuasion as pads tightish on disc, put bolt in and now getting parking brake warning and wheel locked solid. Pressumably this means electronic parking brake needs releasing. can it be done without vagcom?
  10. Re: Knocking noise
    May 2012
    essex
    Ignore last reply as I fixed it. Sort of.
    Well in a way bodged it until I drive it to a garage.
    Took the caliper off and the inside brake pad was worn at an angle due to the caliper hanging off. Removed the pad and levelled it off in a vice with an angle grinder! dust mask on and holding breath.
    Fitted it back into caliper and refitted everything. This time there was enough clearance for the piston to slide in easier.
    Started car and applied park brake on and off couple of times and warning has gone, working perfectly also. Now just need to buy new discs and pads all round and get someone with vagcom to release park brake.
  1. Please Help Knocking noise
    By Mickeymoo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-12-2013, 07:40 AM
  2. Knocking noise
    By Gazza-a4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-01-2013, 06:33 PM
  3. Knocking noise from the O/S....
    By Zeb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-09-2011, 10:09 PM
  4. Knocking noise
    By mikea31.820vt in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-02-2011, 08:20 PM
  5. Question Knocking noise
    By nick.king in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-07-2008, 09:20 PM
