Thread: Sharan headlight range control motor
Results 1 to 8 of 8
  1. Sharan headlight range control motor
    Sep 2007
    I noticed recently that the little dashboard thumb wheel (next to the instrument illumination level control) in my 2001 sharan only changes the range/level of one headlight (nearside). I can't decide if this is normal or not.
    Does anybody know if both headlights should change? - or is it set up so that only one light ever changes?
    I guess I could remove the non-moving headlight to see a motor is actually fitted - but it seemed better to ask here first.
    Thanks for any help you can give.
    SD.
  2. Re: Sharan headlight range control motor
    Dec 2006
    Manchester
    Both lamps should move as far as i'm aware....
    Sounds like a dodgy motor, but check the wiring first, (Maybe use the motor from the other side ) and then if that motor works on both, you just need a new motor.
    Nick
    1.9 tdi PD 100 Bora
    110cc pitbike, 4 speed semi-auto
    110cc Off road buggy, 4 speed semi-auto
  3. Re: Sharan headlight range control motor
    Sep 2007
    I'll try that - thanks!
    SD
  4. Re: Sharan headlight range control motor
    Bristol
    on all the cars ive had that had that feature , both lamps moved together m8 !!
    MK5 Golf TDI 2.0ltr GT Sport in Black
  5. Re: Sharan headlight range control motor
    Dec 2007
    Montrose Scotland
    I have the same situation, what was you result?
  6. Re: Sharan headlight range control motor
    Sep 2007
    In the end I bought a new motor from the local VW garage and fitted it myself. Seemed to cure the problem although I did notice there was quite a lot of "chatter" in the movement whenever the motor was used.
  7. Re: Sharan headlight range control motor
    Dec 2007
    Montrose Scotland
    Was just messing with it today and noticed the motor is working fine,....if you give it a little tap. I could do with just stripping it and having a look.
    How do you get the headlight out once past the 4 bolts holding it in. Does the bumper need to come off? I ran out of time today so fired it all back together.
    Cheers for the info
    Daz
  8. Re: Sharan headlight range control motor
    Dec 2007
    Montrose Scotland
    New motor fitted, Bumper in place, did not need to be removed.
    Headlights both work fine.
  1. Cruise Control on Sharan
    By warbum44 in forum Touran - Sharan - Caravelle
    Last Post: 12-07-2010, 10:24 AM
  2. Sharan - Heater Blower Motor Brushes
    By Paul Sharan in forum Touran - Sharan - Caravelle
    Last Post: 18-02-2009, 10:39 PM
  3. The Commercial Range
    By RickT in forum The Commercial Range
    Last Post: 06-04-2007, 01:41 AM
  4. A3 Range Update
    Last Post: 14-02-2005, 11:35 PM
