Thread: Can bus query
Results 1 to 10 of 13
  1. Can bus query
    May 2009
    rushden
    I have upgraded the radio and fitted the new q canbus and recoded it so exactly the same options are ticked?
    my problem is that the climatronic temp knobs have swapped!....the passenger one is now dominant as though it's lhd.is this something I've missed? Ihe coding is identical although the new canbus has more options!
    Any help would be greatly appreciated.
  2. Re: Can bus query
    Sep 2008
    SE London
    Quote Originally Posted by PHASTAZPHUK View Post
    How did you do the swap? Did you just copy the code in the old module into the new? Or did you note what options were ticked in the old and then ticked those same options in the new?
    Do you have Climatronic or Climatic? There is no coding in HVAC module for Climatronic. There are options in the RNS510 and the 850 that show what your HVAC module's doing. That is for later control panels that don't have the left and right windows. They may have been left on when the radio was last used by previous owner?
    Post your Autoscan and let's see what modules you have and their settings
  3. Re: Can bus query
    May 2009
    rushden
    oimage.jpgCheers for the reply Richard,
    i can't get to the PC so will post my scan results later,I checked all the same options,it's a 2006 sel 170 so may well be climatic
    oops sorry about all the pics it didn't confirm or show insertion,
  4. Re: Can bus query
    Sep 2008
    SE London
    Yep, that's Climatronic.
    You have RCD310. Don't think that displays Climatronic information...
  5. Re: Can bus query
    May 2009
    rushden
    its not the radio thats the problem!its the fact that the left temp knob it now dominant and adjust the temp for both sides
    b4 it was the right hand knob so the driver had overall control,
    its driving me crackers!!!!
    Wednesday,26,February,2014,13:19:49:05782
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.2.0
    Data version: 20140212
    VIN: WVWZZZ3CZ7P072238 License Plate:
    Mileage: 210510km-130804mi Repair Order: 0000001
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 7D
    VIN: WVWZZZ3CZ7P072238 Mileage: 210510km/130804miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-018-BMN.clb
    Part No SW: 03G 906 018 AS HW: 03G 906 018 AS
    Component: R4 2.0l PPD1.2 G 9925
    Revision: --H32--- Serial number: VWZCZ000000000
    Coding: 0000078
    Shop #: WSC 00687 210 71408
    VCID: 76E3E34401D1ABAEB1B-8023
    No fault code found.
    Readiness: N/A
    Address 02: Auto Trans Labels: 02E-927-770.lbl
    Part No SW: 02E 300 043 E HW: 02E 927 770 AE
    Component: GSG DSG 070 1156
    Revision: 04507000 Serial number: 00000609010839
    Coding: 0000020
    Shop #: WSC 00028 028 00001
    VCID: 1623C3C421910BAE51B-8043
    Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
    Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
    Component: ESP 440 C2 H015 0004
    Revision: H015 Serial number: 0668014771
    Coding: 0013629
    VCID: 326B1F54AD39F78E5D3-8067
    Address 08: Auto HVAC Labels: 3C0-907-044.lbl
    Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH
    Component: ClimatronicPQ46 050 0505
    Revision: 00050005 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 67DDBE00567B42263AD-8032
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
    Part No SW: 3C0 937 049 H HW: 3C0 937 049 H
    Component: Bordnetz-SG H37 1301
    Revision: 00H37000 Serial number: 00000004453401
    Coding: E4808F0700041A00000A00000F000000000859435C0000
    VCID: 2E530B24B901D36E39B-807B
    Subsystem 1 - Part No: 3C2 955 119 A Labels: 1KX-955-119.CLB
    Component: Wischer VW461 012 0503
    Coding: 00063445
    Shop #: WSC 00028
    Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
    Component: RLS 120906 014 1201
    Coding: 00208933
    Shop #: WSC 00028
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 J HW: 3C0 909 605 J
    Component: 05 AIRBAG VW8 029 2521
    Revision: 09029000 Serial number: 003A2PCUM45R
    Coding: 0012341
    VCID: 2D510C28B407A876001-8078
    Subsystem 1 - Serial number: 6332MSME1204663A
    Subsystem 2 - Serial number: 6342MSME1228245E
    Subsystem 3 - Serial number: 6351HTS6K5QAL4B3
    Subsystem 4 - Serial number: 6361HTS6K5QAP333
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
    Component: Lenks‰ulenmodul 006 0010
    Revision: 00006000 Serial number: 3C5953507C
    Coding: 0001013
    VCID: 2A5B073485E9BF4EE53-807F
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 960 K HW: 3C0 920 960 K
    Component: KOMBIINSTRUMENT VD1 1614
    Revision: X0006000 Serial number: 00000000000000
    Coding: 0007405
    Shop #: WSC 00687 210 55092
    VCID: 2B5502308A13A6461E5-807E
    Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
    Part No SW: 3C0 907 530 Q HW: 3C0 907 951
    Component: J533 Gateway H13 0172
    Revision: H13 Serial number: 3690P118100484
    Coding: FD807F1600020200F100
    Shop #: WSC 12345 123 12345
    VCID: 2F6D1620BE0BDA6632D-807A
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
    Component: IMMO 042 0383
    Revision: 00042000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: 39792878704F04D69C9-806C
    Subsystem 1 - Part No: 3C0 905 861 F
    Component: ELV 026 0380
    3C0905861F ELV 026 0380
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
    Component: J386 TUER-SG FT 1124
    Revision: 12007001 Serial number: 00000584068917
    Coding: 0000757
    VCID: 3B7532707A7336C68E5-806E
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.136 H07 1806
    VCID: 356124485C57E0B6781-8060
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 042 0472
    Coding: 00910A0001860E763004941570085FCE3078A0
    Shop #: WSC 00764 210 84339
    Subsystem 1 - Component: Sounder No Answer
    Subsystem 2 - Part No: 3C0 951 171 A
    Component: Neigungssensor 002 0508
    Subsystem 3 - Part No: 3C0 951 171 A
    Component: Innenraumueberw.002 0508
    1 Fault Found:
    01134 - Alarm Horn (H12)
    004 - No Signal/Communication
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
    Component: J387 TUER-SG BT 1124
    Revision: 12007001 Serial number: 00000523568925
    Coding: 0000756
    VCID: 3C77316C7F7D31FE87F-8069
    Address 53: Parking Brake Labels: 3C0-907-801-53.clb
    Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
    Component: EPB VC8HC001 013 0001
    Revision: 013
    Coding: 0000012
    VCID: 2149E018F8DF7C16B49-8074
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 5M0 035 186 L HW: 5M0 035 186 L
    Component: Radio RCD310 004 0119
    Revision: 01000001 Serial number: VWZ1Z2M2184201
    Coding: 01000400020001
    Shop #: WSC 00788 648 00255
    VCID: 356124489C57E0B6781-8060
    1 Fault Found:
    02877 - Digital Radio Antenna (R183)
    011 - Open Circuit
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
    Component: J388 TUER-SG HL 1113
    Revision: 11005001 Serial number: 00000000707020
    Coding: 0000208
    VCID: 3D713C68646738F6B01-8068
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
    Component: J389 TUER-SG HR 1113
    Revision: 11005001 Serial number: 00000000675256
    Coding: 0000208
    VCID: 3E733B64696123EEA9B-806B
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
  6. Re: Can bus query
    Sep 2008
    SE London
    its not the radio thats the problem!its the fact that the left temp knob it now dominant and adjust the temp for both sides b4 it was the right hand knob so the driver had overall control, its driving me crackers!!!!
    Yes, understand the problem. Only suggested radio when I thought you had latest "R" version RNS510 (which have a climate display). Thought that's why you changed CANbus module for a "Q" version. I don't think the RCD310/DAB will give you battery drain error but could be wrong for this latest version?
    Suggest you look at what options were ticked when the old module was in place, and instead of just copying the original "C" version code into the new "Q" module as coding; take note of what options are enabled in the old, and tick the same options in the new. I don't have "Q" coz I didn't get an OEM replacement radio -- went with JVC.
    (Autoscan snipped)
  7. Re: Can bus query
    Sep 2008
    SE London
    Forgot to ask: where did the "Q" module come from? Taiwan (new), or a second hand seller, or from VW Spares?
    And is "Dual" working OK?
  8. Re: Can bus query
    May 2009
    rushden
    oh yes it gives battery drain, took about 30 hours. If you mean dual as in dual zone for the air con, its that thats reversed.It works fine just the passenger side controls the whole car on dual not the drivers!
    the Q came new from china via ebay it took 2 weeks to arrive and only cost £35.19 posted.
  9. Re: Can bus query
    May 2009
    rushden
    Any body?
  10. Re: Can bus query
    Sep 2008
    SE London
    Any body?
    But you havn't answered my questions of previous post. This would also tell whether it is your CANbus version "Q" causing this HVAC control fault or not
    Outstanding: "How did you do the swap? Did you just copy the code in the old module into the new? Or did you note what options were ticked in the old and then ticked those same options in the new?
    "Suggest you look at what options were ticked when the old module was in place, and instead of just copying the original "C" version code into the new "Q" module as coding; take note of what options are enabled in the old, and tick the same options in the new."
  1. Where is the CAN BUS gateway?
    By maddogphysics in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-06-2010, 06:33 AM
  2. GOLF V BUS-CAN or BUS R-LADDER ???
    By DSGFAN in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2009, 12:26 AM
  3. Important CAN bus or non CAN bus???
    By linners in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-08-2008, 10:58 AM
  4. Please Help Golf VS Bus...Bus wins
    By LSDJ in forum Golf MK4 - 1999 - 2004
    Last Post: 02-06-2008, 06:32 PM
  5. My Shiny Bus!!!
    By Mr OV51LTA in forum Show 'n' Shine - Post your efforts here
    Last Post: 22-03-2008, 10:28 PM
