Thread: Saving/Recording original settings
Results 1 to 8 of 8
  1. Saving/Recording original settings
    I am shortly going to purchase a genuine VCDS unit but I am aware of the potential slip ups that could happen with it.
    Is there a way to record all the settings in a car when you first connect to it, so after you've messed with things or made a boo boo, you can then just re load them.
    I've a quick look around the forums etc but can't seem to find anything referencing to this,
    Many thanks in advance
    Will
  2. Re: Saving/Recording original settings
    46 Post(s)
    VCDS records all changes automatically.
    C -> Rosstech -> Debug -> CodingLog / AdaptionLog
  3. Re: Saving/Recording original settings
    Thanks Chris,
    Always nice having the comfort of a log to refer back on.
    many thanks
  4. Re: Saving/Recording original settings
    46 Post(s)
    You're welcome.
    For example -
    Code:
    ddress 10:8P0 919 475 C recoded (Long Coding) from 00010B to 10010B  (06751/128/28888)  Monday,24,February,2014,18:18:40:49196
    Address 10:8P0 919 475 C recoded (Long Coding) from 00010B to 01010B  (06751/128/28888)  Monday,24,February,2014,18:19:13:49196
    Address 10:8P0 919 475 C recoded (Long Coding) from 01010B to 00010B  (06751/128/28888)  Monday,24,February,2014,18:19:38:49196
    Address 10:8P0 919 475 C recoded (Long Coding) from 00010B to 00000B  (06751/128/28888)  Monday,24,February,2014,18:20:00:49196
  5. Re: Saving/Recording original settings
    Sort of makes sense Chris,
    In your example, its saving the overall binary total for the 8P0 .. etc module your working on so if I made a boo boo, I'd just reset it to 00010B, being the first recorded value in this example ?
    I guess once I've got my hands on it, it will make a lot more sense.
    Will
  6. Re: Saving/Recording original settings
    46 Post(s)
    Thats it, basically once you start changing bits and pieces it'll list every module you've worked on and give you the before and after coding so easy to revert to should something go wrong.
  7. Re: Saving/Recording original settings
    Sounds good,
    Many thanks for your time this evening ! !
  8. Re: Saving/Recording original settings
    46 Post(s)
    No problemo, you're welcome!
  1. Settings not saving
    By Matt482 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 27-06-2012, 10:51 PM
  2. Question fuel saving tips
    By zakkaz in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-02-2011, 08:27 PM
  3. Saving settings before disconnecting then battery, Radio Code
    By Keithuk in forum Golf MK6 - 2009 - 2013
    Last Post: 26-08-2010, 06:23 PM
  4. evolutionchips fuel saving remaps
    By sr-performance in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-09-2009, 05:17 PM
  5. Fuel Saving Devices
    By kev2963 in forum Archive posts
    Last Post: 14-03-2006, 10:45 PM
