Thread: 01314 - engine control module 49-10 - no communications Fault code
Results 1 to 10 of 18
Hybrid View
  1. 01314 - engine control module 49-10 - no communications Fault code
    May 2011
    Enniskillen Co,Fermanagh
    WELL LADS got this fault code and my turbo isn't boosting till its over 2000rpm.Small note; I remapped it last week using MPPS and a map file from Blacksmock.any help would be appreciated...
    Remapped 2004 130 sport
  2. Re: 01314 - engine control module 49-10 - no communications Fault code
    Oct 2005
    01314 - Ross-Tech Wiki
    See the third item under Possible Causes.
    Can you reflash the original map and see how it performs?
  3. Re: 01314 - engine control module 49-10 - no communications Fault code
    May 2011
    will try and reflash tomorrow
  4. Re: 01314 - engine control module 49-10 - no communications Fault code
    May 2011
    Did the reflash and these are the codes that where left after a spin...
    Tuesday,25,February,2014,16:29:09:64554
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.0.0
    Data version: 20130910
    VIN: WAUZZZ8E35A057793 License Plate:
    Mileage: 286320km-177910mi Repair Order: 25/02/2014
    Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
    67 69 75 76 77
    VIN: WAUZZZ8E35A057793 Mileage: 286320km/177910miles
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 LJ
    Component: 1,9l R4 EDC 0000SG 5934
    Coding: 00002
    Shop #: WSC 63351
    VCID: 6ADB2AAE1683C34E2A7-4B02
    WAUZZZ8E35A057793 AUZ6Z0D0326135
    1 Fault Found:
    17994 - Engine Mount Solenoid Valves (N144/N145)
    P1586 - 35-10 - Short to Plus - Intermittent
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front 4529
    Coding: 04255
    Shop #: WSC 06435
    VCID: E5C1D9927F9D6C36875-5122
    1 Fault Found:
    18258 - Powertrain Data Bus
    P1850 - 35-10 - Missing Message from ECU - Intermittent
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AA
    Component: A4 Klimaautomat 1424
    Coding: 00000
    Shop #: WSC 63351
    VCID: 60CF4886E0BF891EF43-5140
    1 Fault Found:
    00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
    09-00 - Adaptation Limit Surpassed
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 C
    Component: int. Lastmodul RDW 0606
    Coding: 00001
    Shop #: WSC 63351
    VCID: 326BF2CEFED34B8E527-4B1A
    No fault code found.
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 J
    Component: Airbag 8.4EP 1002
    Coding: 0011602
    Shop #: WSC 63351 000 00000
    VCID: 3E73D6FE6A8B9FEEA6F-5140
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 S
    Component: Lenksáulenmodul 0611
    Coding: 01001
    Shop #: WSC 63351
    VCID: 4385A70A5169F206C91-4B1A
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 M
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 00401
    Shop #: WSC 00186
    VCID: 3365F7CA01C94286591-515C
    1 Fault Found:
    01314 - Engine Control Module
    49-10 - No Communications - Intermittent
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0704
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBD5AFAA99795A46D11-5122
    Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
    Part No: 8E0 959 433 BD
    Component: Komfortgerát TBF 1712
    Coding: 06859
    Shop #: WSC 63351
    VCID: 74E734D6444705BE80B-4B02
    Subsystem 1 - Part No: 8E2959802B
    Component: Tõrsteuer.FS BRM 0205
    Subsystem 2 - Part No: 8E2959801B
    Component: Tõrsteuer.BF BRM 0205
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 186 L
    Component: concert II GRO 0001
    Coding: 01011
    Shop #: WSC 63251
    VCID: 306FF8C6F0DF799E243-4B02
    2 Faults Found:
    01300 - Control Module for Navigation with CD-Rom (J401)
    49-00 - No Communications
    00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
    36-10 - Open Circuit - Intermittent
  5. Re: 01314 - engine control module 49-10 - no communications Fault code
    Oct 2005
    How is the turbo performing with the original map back in place?
    The 01314 code is quite common when using a clone cable - is your cable an eBay special?
    Everything points to a comms error between the ECU and the rest of the car, check the loom for any breaks and check the connection is sound.
  6. Re: 01314 - engine control module 49-10 - no communications Fault code
    May 2011
    Turbo not boosting now. And yes it is a ebay special. Also getting a new abs fault
    Do ya think iv fryed the ECU....
  1. Replies: 5
    Last Post: 15-10-2012, 10:20 PM
  2. Non Starter - VAG Code 01314
    By hapz1 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-05-2010, 10:53 PM
  3. Replies: 0
    Last Post: 09-07-2009, 03:35 PM
  4. Replies: 0
    Last Post: 09-07-2009, 03:03 PM
  5. control module code
    By novadan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-03-2009, 03:53 PM
