Thread: Low oil pressure
  1. Low oil pressure
    Hi , missus rang me this mornin saying the low oil pressure light was on . She stopped the car straight away and checked the oil level which was ok. Started the car back up and drove 60 miles to work no problem.started the car at dinner time and no warning sign until she started accelerating when it came on again an went back out. I popped there and fitted a new pressure switch but doesn't see to have fixed it . Any ideas , is it the start of oil pump failure or is there any point in changing the sensor on the sump?
  2. Re: Low oil pressure
    Pembrokeshire
    22 Post(s)
    welcome to the forum.
    what is the engine code.
  3. Re: Low oil pressure
    Hi, thanks for the reply it's a 2005 blb , she's done 198k now , there's no abnormal engine noise , no loss of power or smoke . Oil levels fine , would it be worth using an engine flush incase the strainer/ pick up is partially blocked
  4. Re: Low oil pressure
    Pembrokeshire
    22 Post(s)
    i would put blb in the search box and see what comes up. i would presume yours has already been modified though.
    what i definitely wouldn't do though is put a flush through it, just in case. i would be getting the sump off pronto before going anywhere in it.
  5. Re: Low oil pressure
    Dec 2006
    Stoke/Congleton
    Do not drive this car until you have the oil pump sorted.This is a big job but you will need the sump off and oil pump off to look at any damage.
    It sounds like your engine should be OK though.
    If you drive it any more with dodgy oil pressure you risk the turbo going and engine trouble.
  6. Re: Low oil pressure
    Hi all , it was the oil pump gear and drive chain . Thankfully not as expensive a job as it could have been , sounds like the chain was slipping as the revs increased just don't understand why we never heard anything at all .
  1. oil pressure low
    By markanthony73 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-02-2011, 11:48 AM
  2. Oil pressure low
    Last Post: 23-11-2010, 10:36 PM
  3. Oil Pressure Low
    By csmccoll68 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-12-2009, 07:31 PM
  4. Low Oil pressure
    By sprintevo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-05-2008, 09:22 AM
  5. low oil pressure..
    By gibo in forum Audi A3 - Archive Topics
    Last Post: 11-12-2007, 11:43 PM
