Thread: AirCon faulty at low speeds - Polo 2001
Hybrid View
  1. AirCon faulty at low speeds - Polo 2001
    Sep 2007
    Hi Guys & Gals,
    I have a problem with my aircon. At low speeds (i.e. Stand still to 20mph), I put the aircon on but it switches itself off after 30secs or so. It comes back on itself after a minute or so for about 10secs then goes off again. However, when the car is moving the aircon STAYS on and there is no problem.
    I've tried re-gassing it but that has not resolved it. Is this a job for an aircon specialist or is their a common fault like the Seat Leon and the fault low speed fan sensor?
    Thanks in advance!!
  2. Re: AirCon faulty at low speeds - Polo 2001
    135 Post(s)
    2038 Post(s)
    Your cooling fan probably isn't coming on when the A/C is on. Turn on the A/C and see if the fan runs. When you are driving along, road draught takes over so the fan isn't required.
  3. Re: AirCon faulty at low speeds - Polo 2001
    Sep 2007
    I don't hear the fan come on at all when i put the air con on. Sounds like that may well be the problem. If we assume the fan does work, where would the fan sensor be that tells the fan to come on? I'm thinking i could try replacing this before i try replacing the fan unit itself
  4. Re: AirCon faulty at low speeds - Polo 2001
    135 Post(s)
    2038 Post(s)
    Send me your chassis number by PM and I can tell you the details of what to check.
  1. Polo Aircon Probs.
    By llewellyn in forum Polo - Derby - Lupo - Fox
    Last Post: 16-08-2007, 07:49 PM
  2. 2001 polo fuel filter
    By kem in forum Polo - Derby - Lupo - Fox
    Last Post: 08-05-2007, 01:04 PM
  3. VW POLO 1.0 E 2001
    By truezebra in forum Polo - Derby - Lupo - Fox
    Last Post: 08-01-2007, 02:00 PM
  4. Polo 2001
    By polo761 in forum Polo - Derby - Lupo - Fox
    Last Post: 04-10-2006, 07:57 PM
  5. Problem with ABS on Polo 2001 1.4L
    By lyonelk in forum Polo - Derby - Lupo - Fox
    Last Post: 12-08-2006, 09:08 AM
