Thread: 2.0TDI Multitronic Rough/Lumpy Idle
Results 1 to 10 of 15
  1. 2.0TDI Multitronic Rough/Lumpy Idle
    May 2013
    Atherton, England
    I have recently had my faulty Multitronic ECU repaired which I hoped would also cure the rough lumpy idle my car has, but unfortunately it hasn't.
    Basically when the car is still the engine stutters and the rev needle bounces from 600rpm to 1000rpm, however if I put the Multitronic box into Neutral 'N' the problem isn't quite as bad.
    When the engine finally reaches normal operating temperature the problem isn't too obvious but there is still a faint stutter that can be felt in the car when stationary.
    I've been told it could be a timing issue as a result of a recent timing belt replacement, I've also been told it could be related to a faulty EGR or faulty injectors.
    Incidentally the car does have the worn DMF which results in a rough noisy start of the engine when hot, it's been suggested this may also be causing the rough lumpy idle.
    Any ideas where I should look first?
  2. Re: 2.0TDI Multitronic Rough/Lumpy Idle
    46 Post(s)
    When was the multitronic oil last changed?
  3. Re: 2.0TDI Multitronic Rough/Lumpy Idle
    May 2013
    Atherton, England
    About 3 weeks ago when the Multitronic ECU was repaired.
  4. Re: 2.0TDI Multitronic Rough/Lumpy Idle
    May 2013
    Atherton, England
    Can anyone offer any advice? I must say I'm hugely disappointed with the 2.0TDI unit. Compared to diesel units in other cars I've owned, namely a BMW derived 2.0 in a Rover 75 and a Ford/PSA 2.2 unit in a Citroen C5, the Audi is very unrefined.
    On the other hand the 2.7TDI V6 in my other A6 is excellent.
  5. Re: 2.0TDI Multitronic Rough/Lumpy Idle
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    Age? Miles? the 2.7 will be smoother cos it's a v6 lump, much more refined. My old 2.ltr Passat sounded like a taxi at idle.
  6. Re: 2.0TDI Multitronic Rough/Lumpy Idle
    May 2013
    Atherton, England
    It's 2008 so 6 years old with 103,000 miles. Full Audi service history.
  7. Re: 2.0TDI Multitronic Rough/Lumpy Idle
    May 2013
    Atherton, England
    It's getting worse! It was so lumpy, jumpy today that the engine cut out.
  8. Re: 2.0TDI Multitronic Rough/Lumpy Idle
    46 Post(s)
    Time to get it to a good Audi specialist or Audi themselves.
  9. Re: 2.0TDI Multitronic Rough/Lumpy Idle
    May 2013
    Atherton, England
    I'm off to Tunisia soon so leaving it at VAG Bolton for a week. Whatever happens I ain't paying a penny because I've only owned the car since late December and the fault has been present all the time.
  10. Re: 2.0TDI Multitronic Rough/Lumpy Idle
    46 Post(s)
    Did you buy from a trader?? You have a minimum 3 month warranty.
  1. A3 Sportback 2.0tdi - Rough Idle
    By Gavsta88 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 04-03-2013, 04:42 PM
  2. 2.0TDi Lumpy idle
    By Camper67 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-02-2013, 04:58 PM
  3. Rough idling & lumpy acceleration 2.7T
    By nigelbb in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-07-2011, 07:52 AM
  4. Question Rough/Lumpy idle on A4 2.0tdi
    Last Post: 09-05-2010, 12:32 PM
  5. Question A4 2.6 rough idle/rough at high rpm
    By teccyjim in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-09-2008, 07:22 PM
