Thread: Help & advise on rns315 satnav unit with bluetooth
Results 1 to 10 of 13
  1. Help & advise on rns315 satnav unit with bluetooth
    Oct 2013
    Coventry
    Hi everyone,
    I have the VW Sharan 2013 model. It comes equipped with RCD310 radio with built-in Bluetooth and OPS (Optical Parking Sensors). I have bought the RNS315 with built-in Bluetooth and GPS antenna to replace the RCD radio. Will I need anything else ie microphone or any other cables etc? And is it a straight forward swap over? Any help or advise is much appreciated!
    thanks
  2. Re: Help & advise on rns315 satnav unit with bluetooth
    Jul 2011
    manchester
    Hope you get a better response than me!!!
  3. Re: Help & advise on rns315 satnav unit with bluetooth
    46 Post(s)
    If the BT was installed from factory then it should just connect using the same quadlock connector from the original stereo apart from the additional GPS antenna cable.
    You might need it coded with VCDS to suit the options in your car.
  4. Re: Help & advise on rns315 satnav unit with bluetooth
    Oct 2013
    Coventry
    Hi Chris, thanks for the reply! It's a brand new VW Sharan and the radio comes with the car and have BT built-in. How would I tell after installing RNS315 unit if it will need re-coded? Do I need to take to VW dealer? If so, do you know how much?
  5. Re: Help & advise on rns315 satnav unit with bluetooth
    46 Post(s)
    Not necessarily, you might need to tell the unit you have a MFSW, country settings etc.
    If you look at the vcds map link in my forum signature you might see someone who has vcds near you and could help.
    If so, tell me who and I'll try and get them to help as you can't PM until you have 10 posts
  6. Re: Help & advise on rns315 satnav unit with bluetooth
    Oct 2013
    Coventry
    I'll check your link and see who's near me. I'll be installing RNS315 unit on Tuesday so will let you know how I get on. Thanks once again Chris!
  7. Re: Help & advise on rns315 satnav unit with bluetooth
    Oct 2013
    Coventry
    Quote Originally Posted by bobfish45 View Post
    Hello mate, Did you carried out the same work?
  8. Re: Help & advise on rns315 satnav unit with bluetooth
    Jul 2011
    manchester
    No Kit, I installed the module which works perfectly after being turned on by vagcom, I just can't find the connector on the harness for the microphone.
  9. Re: Help & advise on rns315 satnav unit with bluetooth
    46 Post(s)
    Which harness did you use?
  10. Re: Help & advise on rns315 satnav unit with bluetooth
    Jul 2011
    manchester
    Thanks for the reply, I used a genuine vw module and harness, and a vw microphone, however, apart from the two little white connectors on the harness, there seems nowhere to attach the microphone, and of course those two connectors are different to the fitting on the mic.
  1. Voice contol for Bluetooth Phone on RNS315
    By B7Rob in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 05-02-2016, 03:08 PM
  2. Question Satnav unit
    By kimbie in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-07-2011, 10:24 AM
  3. Question Audi satnav plus - bluetooth
    By Macdoon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-11-2010, 07:28 PM
  4. Question A3 Replacement Head Unit - iPod & Bluetooth
    By Charles68 in forum In Car Entertainment
    Last Post: 18-07-2010, 08:59 AM
  5. Question What satnav unit is this
    By scooby_d0o in forum In Car Entertainment
    Last Post: 05-05-2009, 12:08 PM
