Thread: V157 Intake Manifold Flap Issue
  1. V157 Intake Manifold Flap Issue
    Dec 2011
    Bishops Stortford
    I have just scanned my car as other half said something wrong and below codes came up.
    Code:
    19557 - Motor for Intake Manifold Flap (V157)
                P3101 - 009 - Open or Short to Ground - Intermittent - MIL ON
                 Freeze Frame:
                        Fault Status: 10100100
                        Fault Priority: 1
                        Fault Frequency: 42
                        Reset counter: 28
                        Mileage: 162325 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 11:51:43
                 Freeze Frame:
                        RPM: 640 /min
                        Text:    152    Nm
                        Speed: 0.0 km/h
                        Text:  0.0    %
                        Voltage: 10.28 V
                        Text:   1016    Nm
                        Text:     96    Nm
    17058 - Cylinder 4 Glow Plug Circuit (Q13)
                P0674 - 006 - Electrical Fault - MIL ON
                 Freeze Frame:
                        Fault Status: 11100001
                        Fault Priority: 1
                        Fault Frequency: 15
                        Reset counter: 28
                        Mileage: 162325 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 11:51:45
                 Freeze Frame:
                        RPM: 928 /min
                        Text:     56    Nm
                        Speed: 0.0 km/h
                        Text:  0.0    %
                        Voltage: 11.30 V
                        Bin. Bits: 00110000
                        Temperature: 8.0°C
    17075 - Fan 1 Control Circuit
                P0691 - 007 - Short to GND - Intermittent
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 0
                        Fault Frequency: 42
                        Reset counter: 28
                        Mileage: 162325 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 11:51:59
                 Freeze Frame:
                        RPM: 896 /min
                        Text:     48    Nm
                        Speed: 0.0 km/h
                        Text:  0.0    %
                        Voltage: 14.24 V
                        Load: 9.8 %
                        Temperature: 38.0°C
    19558 - Motor for Intake Manifold Flap (V157)
                P3102 - 006 - No Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00100001
                        Fault Priority: 5
                        Fault Frequency: 14
                        Reset counter: 49
                        Mileage: 162442 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 16:42:22
                 Freeze Frame:
                        RPM: 768 /min
                        Text:     24    Nm
                        Speed: 0.0 km/h
                        Text:  0.0    %
                        Voltage: 14.13 V
                        Text:    184    Nm
                        Text:      0    Nm
    Readiness: N/A
    Now the glow plug issue i have put off and I know about but the V157 issue is what i need some advice on. I plan on ordering a new part from TPS next week and presume it is just remove the old and put in new one. GSF seem to do one but is over £200 and will see if TPS can do cheaper.
    Also the fan issue as i have been reading seems to be linked to the V157 issue and possibly be a faulty fuse. The car shudders a lot when stopping so guess it is definitely knackered.
    Any help on either of these issues is much appreciated.
    Last edited by Sam; 18-02-2014 at 12:32 PM. Reason: Fixing font and huge line spacing
  2. Re: V157 Intake Manifold Flap Issue
    Norfolk
    Fan is on same fuse so when flap failed, the fuse blew. Fit new flap and replace fuse. Flap can be repaired but it is very difficult and you need a spare one for parts so it's not really worth the effort. Especially as they mostly all break in the same way. so the bits you need from a spare flap are already broken.
  3. Re: V157 Intake Manifold Flap Issue
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Quote Originally Posted by martin1810 View Post
    Martin, you sound as though you have previous experience of repairing this V157 Manifold Flap.
    Is there anything that can be done to a working unit to prevent it failing in the future ?
    What is it that fails ?
    Any heads-up would be appreciated.
  4. Re: V157 Intake Manifold Flap Issue
    Dec 2011
    Bishops Stortford
    Dont suppose you know what fuse number it is. I am just going to get a new one I think. Havent got a spare. Seems like plastic cogs could be issue
    Sent from my GT-I9505 using Tapatalk now Free
  5. Re: V157 Intake Manifold Flap Issue
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    ' Seems like plastic cogs could be issue '
    Sounds about right for a £200 unit.
    According to Martin's excellent site
    https://sites.google.com/site/1810martin/passat-b6-fuse-assignment
    it's Fuse SB23 in the engine bay left fuse box.
  6. Re: V157 Intake Manifold Flap Issue
    Norfolk
    Quote Originally Posted by philipharmes View Post
    They suffer from blown motors, plastic cog breakage etc. No one single fault But cog breakage is very common. There isn't much you can do to prevent future failing. Keep fingers crossed!!
  7. Re: V157 Intake Manifold Flap Issue
    Dec 2011
    Bishops Stortford
    Thanks for your replys.
  1. Motor for Intake Manifold Flap (V157): Malfunction
    By b1nuzz in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-11-2019, 02:46 PM
  2. P3103 V157 - Motor Intake Manifold Flap
    By James Clews in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-02-2014, 09:33 PM
  3. Intake manifold flap
    By john-mandy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-12-2010, 11:48 PM
  4. Intake Manifold Flap (V157)
    By SebastianTDI140 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-06-2010, 08:07 PM
  5. Motor Intake Manifold Flap
    By daveaustin in forum Archive posts
    Last Post: 06-12-2007, 04:39 PM
