Thread: Squeaky Back Wheel
Results 1 to 9 of 9
  1. Squeaky Back Wheel
    Mar 2010
    Canterbury United Kingdom
    Hi everyone!
    Just a quick question:
    When I turn right at a roundabout sometimes I hear a squeak from one of the back wheels. This also happens (again only sometimes) when I'm moving very slow, usually when arriving home and going slowly down the drive. Its not bothering me that much but I just thought id put it out there.
    Thank you
    2009 A3 1.9 TDIe SE
    1999 A4 Avant 1.9 TDI SE
  2. Re: Squeaky Back Wheel
    Feb 2014
    Hertfordshire
    Sounds like an odd one. Does it have disc or drum brakes at the rear? Could be a little seized on that side causing a squeak. Or perhaps a bush being that it's more noticed going round corners when the weight of the car is shifting.
  3. Re: Squeaky Back Wheel
    Mar 2010
    Hello,
    Yes it's weird, I have discs all round.
    2009 A3 1.9 TDIe SE
  4. Re: Squeaky Back Wheel
    Feb 2014
    Hertfordshire
    Might be worth just checking the tread left on both sides of the rear pads that way you can see if they are wearing un evenly. If they are it's a good chance they are sticking.
  5. Re: Squeaky Back Wheel
    Mar 2010
    Ok thanks ill check it out.
    2009 A3 1.9 TDIe SE
  6. Re: Squeaky Back Wheel
    Near Blackpool
    48 Post(s)
    Slam the brakes on a few times that usually clears any brake squeaks but sounds like a knackered bush to me
  7. Re: Squeaky Back Wheel
    Mar 2010
    Had to slam the braked on the other day when I saw a massive pot hole at the last second. Hasn't squeaked since then!
    2009 A3 1.9 TDIe SE
  8. Re: Squeaky Back Wheel
    Near Blackpool
    48 Post(s)
    Good good :-)
  9. Re: Squeaky Back Wheel
    Feb 2014
    Hertfordshire
    Glad to hear it's all sorted what ever was squeaking has been loosened off.
  1. Squeaky Steering Wheel Passat 2002
    By tweever in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-02-2017, 02:36 PM
  2. Squeaky steering wheel.......
    By Rosscow in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-11-2012, 10:55 PM
  3. A4 slip ring squeaky steering wheel
    By portovechios in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-03-2010, 05:42 PM
  4. Audi A4 Front N/s Wheel Suspension Squeaky Noise
    By cbi004 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-07-2009, 12:29 PM
  5. Squeaky noise from drivers side front wheel and harsh gear change (triptonic)
    By jasear in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2008, 02:20 AM
