Audi A6 weird faults - anyone seen these all together? –
12-02-2014,10:46 PM
Car has come to me with no other complaints other than one which is no interior heater fan, that's it!
Here's the scan:
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Wednesday,12,February,2014,18:17:38:32179
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 42 46 4F 52 53 56 5F 62 72
VIN: WAUZZZ4F39N010180 Mileage: 156500km/97244miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine (J623-CAGB) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 FL HW: 03L 906 022 FG
Component: R4 2,0L EDC H01 3810
Revision: 11H01--- Serial number:
Coding: 0105002C02072120
Shop #: WSC 02335 785 00200
ASAM Dataset: EV_ECM20TDI03L906022FL A01009
ROD: EV_ECM20TDI03L906019AF.rod
VCID: 74EDF898DFC69CBE80B-8021
3 Faults Found:
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 154648 km
Date: 2013.11.22
Time: 14:12:21
4339 - Please Check Fault Codes in Control Module for HVAC (J301)
U1025 00 [040] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 49
Mileage: 154090 km
Date: 2013.11.05
Time: 14:43:05
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [040] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Mileage: 154090 km
Date: 2013.11.05
Time: 16:37:28
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 4F5 910 157 F HW: 01J 927 156 JG
Component: V30 01J 2.0l CR RdW 0010
Revision: --H05--- Serial number: 00000000000165
Coding: 0000001
Shop #: WSC 02325 785 00200
VCID: 2C5D20F88F76847E18B-8079
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AK HW: 4F0 614 517 AT
Component: ESP8 front H01 0060
Revision: 00000000 Serial number: 00000000000000
Coding: 0020856
VCID: 6DDBEDFC74EC4D764F5-8038
1 Fault Found:
01200 - ABS Valves Supply Voltage
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 223
Mileage: 154648 km
Time Indication: 0
Date: 2013.11.22
Time: 14:12:22
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0002
Hex Value: 0x8195
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602601205054
Coding: 0000019
Shop #: WSC 02324 785 00200
VCID: 254BD5DCEC9CB536C75-8070
Subsystem 1 - Part No: 4F0 910 132 G
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 B HW: 4F2 820 043 T
Component: KLIMABETAETIGUNGH30 0070
Revision: 00000073 Serial number: 00000030390401
Coding: 0001044
VCID: 1D3BFD3CC4CC7DF69F5-8048
3 Faults Found:
02071 - Local Databus
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 184
Mileage: 154662 km
Time Indication: 0
Date: 2013.11.23
Time: 14:00:31
00256 - A/C Pressure/Temperature Sensor (G395)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 26
Reset counter: 6
Mileage: 154662 km
Time Indication: 0
Date: 2013.11.23
Time: 15:53:47
01844 - Control Module for Fresh Air Blower (J126)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 222
Mileage: 156468 km
Time Indication: 0
Date: 2014.02.12
Time: 16:54:01
Freeze Frame:
Temperature: 10.0°C
Speed: 95.0 km/h
(no units): 27.0
(no units): 94.0
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 N HW: 4F0 907 279
Component: ILM Fahrer H22 0320
Revision: 00000000 Serial number: 4F0907279
Coding: 0008121
VCID: 346D38985746DCBE40B-8061
Subsystem 1 - Part No: 4F2 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H10 0040
Coding: 00056595
Shop #: WSC 02335
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00146221
Shop #: WSC 02335
1 Fault Found:
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 224
Mileage: 154660 km
Time Indication: 0
Date: 2013.11.22
Time: 15:06:00
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 L HW: 4E0 035 110 A
Component: CDC-MP3-Pana H47 0050
Revision: 00000011
VCID: 2143C1CC38B45916BBD-8074
1 Fault Found:
02446 - Disk Drive Mechanical Malfunction
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 227
Mileage: 154937 km
Time Indication: 0
Date: 2013.12.10
Time: 11:58:16
Address 15: Airbags (J234) Labels: 4F0-910-655-10.clb
Part No SW: 4F0 910 655 L HW: 4F0 959 655 E
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 30314236303630303033554A305234463053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 306534886B5EE09E243-8065
Crash sensor for side airbag; driver side:
Serial number: 3574SRB400007E8921CD
Crash sensor for side airbag; passenger side:
Serial number: 3584SRB400007E84C25D
Crash sensor for side airbag; rear driver side:
Serial number: 35152RB402L7EMTAP45P
Crash sensor for side airbag; rear passenger side:
Serial number: 35252RB402P7EMTARSS-
Crash sensor for front airbag; driver side:
Serial number: 3554NRB400004581E0D+
Crash sensor for front airbag; passenger side:
Serial number: 3564NRB400004200953K
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90055082620421
Coding: 0102141
VCID: 2757DFD49690A726F59-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments (J285) Labels: 4F0-920-xxx-17.clb
Part No SW: 4F0 920 983 B HW: 4F0 920 983 B
Component: KOMBIINSTR. H06 0133
Revision: 00100000 Serial number: 9G144C798
Coding: 2F56090502002600010400
Shop #: WSC 02399 823 56573
VCID: 2B5F23E44A788346111-807E
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
Part No SW: 4F0 907 468 F HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0024
Revision: 4LA70021 Serial number: 2100L08927804C
Coding: 000303
VCID: 32613E806D52D28E527-8067
Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
Component: J367-BDM H07 0100
Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000100313613
Coding: 011C06204041410001
VCID: 46897250F1DA5E2EEEF-8013
3 Faults Found:
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 224
Mileage: 154090 km
Time Indication: 0
Date: 2013.11.05
Time: 12:07:58
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 224
Mileage: 154648 km
Time Indication: 0
Date: 2013.11.22
Time: 14:08:01
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 224
Mileage: 154648 km
Time Indication: 0
Date: 2013.11.22
Time: 14:16:41
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
Component: Komfortgeraet H28 0240
Revision: 02400028 Serial number: 01146328020000
Coding: 0131579
VCID: 356B059C5C3CC5B6775-8060
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 33
Reset counter: 224
Mileage: 154090 km
Time Indication: 0
Date: 2013.11.05
Time: 12:07:59
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000586369
Coding: 0001104
VCID: DEB93A30094AA6EE46F-808B
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 224
Mileage: 154088 km
Time Indication: 0
Date: 2013.11.05
Time: 12:07:00
Freeze Frame:
Voltage: 12.100 V
Temperature: 20.0°C
Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000100320970
VCID: 458B755CCCDC5536E75-8010
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 224
Mileage: 154090 km
Time Indication: 0
Date: 2013.11.05
Time: 12:07:57
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0000131
Shop #: WSC 02145 785 00200
VCID: 2143C1CCF8B45916BBD-8074
Address 56: Radio Labels: Redir Fail!
Part No SW: 4F0 035 056 B HW: 4F0 035 056
Component: Radio U STD H43 Radio U STD H43 00200020
Coding: 010003020100000000
VCID: 1F47C7340EC06FE68D9-804A
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4E0 035 666 B HW: 4E0 035 666
Component: H-BN-EU H60 0047
Revision: -------- Serial number: 345JY087526315
Coding: 01010100000283EC01000314EF6300030001
Shop #: WSC 00568 210 91530
VCID: 254BD5DC2C9CB536C75-8070
Subsystem 1 - Part No: 8R0 060 884
Component: EUROPE 2008 5505
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Subsystem 3 - Part No SW: 4F0 910 609 E HW: 4F2 919 611 M
Component: Bedienteil MM H01 0060
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000100298184
Coding: 010804204041220001
VCID: 438F6B44C2E86B06C91-8016
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000100316616
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 224
Mileage: 154648 km
Time Indication: 0
Date: 2013.11.22
Time: 14:08:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 224
Mileage: 154648 km
Time Indication: 0
Date: 2013.11.22
Time: 14:16:41
Audi A4 2.0 TFSi DTM, Quattro, 2006, 220 BHP, Sprint Blue, Multi Spoke Alloys, Light pack, Bi-Directional Xenons, Auto Wipers, Recaro/Electric/Leather/Alcantara/Heated/Memory Seats, Under seat storage, Carbon Fibre spoilers, Carbon Fibre trim inserts, RNS-E Sat Nav, Bluetooth Phone Prep, SDS, FBMFSW, .....
