Thread: Update from 2g to 3G
Results 1 to 10 of 10
  1. Update from 2g to 3G
    Feb 2014
    Northampton
    Hi all I have a high 2g system does anyone know if u can upgrade to 3 g just by changing the control unit ?
    2006 A6 3.0 TDi Avant Quattro Tiptronic Le Mans
    fully mapped
    Bi-Xenons, Advanced Park Assist with rear view camera, MMI 2G High Nav, Dab & 6 CD Changer, rear load blind, Bluetooth.
  2. Re: Update from 2g to 3G
    Buckinghamshire
    Noooooo. Everything 2G must go. radio, antenna amps, MMI screen, Controller.......
    Sent from my iPad using Tapatalk HD
  3. Update from 2g to 3G
    46 Post(s)
    It's not as easy as that. Basically you're ripping everything out MMI related apart from your cd changer. You also need a new aircon unit and instrument cluster.
    Beat to the post but yeah not cheap. Better buying a facelift car!
  4. Re: Update from 2g to 3G
    Feb 2014
    Northampton
    Nah stick wiv what I got then just was offered a cheap 3G unit I like the car just needs the powerfold mirrors lol is there a how to any where Chris ? Not been able to find one yet
    rgds
    fully mapped
  5. Re: Update from 2g to 3G
    46 Post(s)
    Before buying anythig check your door modules are compatible. A scan of vcds to get the PN is your first step.
  6. Re: Update from 2g to 3G
    Feb 2014
    Northampton
    They end with an e I believe but if there powerfold compatible will it show in the coding ?
    rgds
    fully mapped
  7. Re: Update from 2g to 3G
    46 Post(s)
    Should do. You'll need new mirror bases, new mirror adjustment knob and surrounding trim and of course coding.
  8. Re: Update from 2g to 3G
    Feb 2014
    Northampton
    I got a quote for the bases £200 each from Audi wasn't bothered bout the switch just wanted to get them to open and close from the key when u lock and open
    fully mapped
  9. Re: Update from 2g to 3G
    46 Post(s)
    That's not possibe on the C6 without complicated wiring modifications.
    £400 is a bit much for me considering you can fold them in manually within 30seconds and for free
  10. Re: Update from 2g to 3G
    Feb 2014
    Northampton
    Been quoted around 750 for richter sport to supply and fit a full conversion I want it done just liked the idea of doing myself
    fully mapped
  1. Q7 Update?
    By Ja jay deeeeEEE in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 21-07-2011, 04:14 PM
  2. Update!
    By scenicart in forum Golf MK6 - 2009 - 2013
    Last Post: 10-01-2010, 02:00 AM
  3. Question Software update
    By shottdi in forum Jetta MK3 - 2005 - 2013
    Last Post: 28-09-2009, 09:46 PM
  4. Navi Update
    By markvw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-09-2008, 08:56 PM
  5. An update
    By Bloater in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-03-2008, 11:13 PM
