Thread: K-line RNS-E
  1. K-line RNS-E
    Feb 2014
    horsham
    Hi everyone
    Got a weird problem with rns-e and hoping you can shed some light.
    VCDS does not comunicate with RNS-E (factory fitted). All wiring is correct at the rns-e.
    NOW, when i test the wiring the resualts are as follow:
    Diag socket (pin 7) to k-line on rns-e --> no continuity
    Diag socket (pin 7) to k-line on climate unit --> continuity ok
    k-line on climate unit to k-line on rns-e --> continuity ok (logically speaking, if I should be able to comunicate with radio if vcds finds addr 08 (Auto HVAC) ??????
    When I disconnect rns-e and run the test on instruments or electrics, the I get an error
    that rns-e not detected (which is correct), with rns-e reconnected error disappears, but still
    no connection via vag-com.
    Any ideas ??
  2. Re: K-line RNS-E
    Aug 2013
    United Kingdom
    The RNS-E is on K2 (pin 15) (there is a second, totally separate pin in the diagnostic socket which is a 2nd K-Line, on most A4's the radio is the only thing on it).
    My guess:- Your clone VCDS cable has a broken or missing K2 interface.
    Test: continuity between RNSE K-line pin and diag socket pin 15. If that works then that's probably your problem.
    Incidentally, I have found previously that VCDS's "clever algorithm" for selecting which K-Line to use is simply to try and contact a controller on both K-Lines and use the one that succeeds. Therefore, if your VCDS cable is broken (assuming it's a legitimate one of course) then you could probably hotwire the vcds cable into the plug (pins 4 and 16 for power, and then VCDS pin 7 (K1) to the car's pin 15 (k2). It will then work but only for the RNSE, but don't blame me if you kill your cable / laptop / car / dog.
  3. Re: K-line RNS-E
    Aug 2013
    United Kingdom
    Quote Originally Posted by polmark View Post
    Hi everyone
    That is because the instruments talk to the RNSE via CAN not the K-Line. RNSE uses KLine only for diag and programming. Assuming you're retrofitting you just need to get it programmed one time only and you're done.
    1 1 0
  1. CC Rline Tdi - views plus RNS 315 v RNS 510
    By mkenn in forum Passat CC
    Last Post: 10-01-2014, 11:18 PM
  2. Question Is RNS-315 to RNS-510 upgrade worth it ?
    By LazLon in forum Tiguan
    Last Post: 03-11-2013, 07:35 PM
  3. K Line problem with both radio + rns-e
    By slippyr4 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-10-2013, 09:19 PM
  4. RNS-315 to RNS-510
    By neilsafc in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 19-07-2011, 10:48 AM
  5. Installation of AUDI bluetooth kit for RNS-E RNS
    By 519ryan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-05-2011, 09:14 PM
