Thread: Wet wet wet
  1. Wet wet wet
    Feb 2007
    Poole
    Had damp issues recently, and noticed nsr seatbelt keeps going mouldy along the entire length. Just had boot panel off and the ns is damp. Can't see any obvious routes - have sealed the number plate lights and couple spare holes for the plate. Anyone any ideas?
  2. Re: Wet wet wet
    Mar 2008
    Just Cumbria now.
    Saloon or Estate?
    If estate most probably be rear washer pipe split/disconnected somewhere.
    Nothing to see here, move along..
  3. Re: Wet wet wet
    Feb 2007
    Poole
    Ah good shout! Is a saloon.
    When opening boot, is a little damp on seal and boot where they join. Have adjusted catch down, and looked at rubber adjusters but can't adjust them.
  4. Re: Wet wet wet
    Mar 2008
    Just Cumbria now.
    Try rear lights, they are also know to leak around the seals.
  5. Re: Wet wet wet
    Feb 2007
    Poole
    Good call, it is wet in ns around that area. Usual fix of bang a load of silicone round the seal on these?
  6. Re: Wet wet wet
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by JustinM3 View Post
    It wouldn't hurt
  7. Re: Wet wet wet
    Feb 2007
    Poole
    Think you called it, foam seal was a bit soggy. Siliconed both sides. Doesn't seem firm enough to be 100% water tight really.
    Those studs on the light break easy.....
  1. Wet thru - headlining..........
    By roosevelt1st in forum Golf MK3 - 1993 - 1999
    Last Post: 26-06-2012, 03:38 PM
  2. Question Wet Carpets
    By Gary.Townend in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-05-2010, 04:00 PM
  3. Wet Wet Wet
    By davo79 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-02-2009, 10:05 AM
  4. wet windows
    By vygec in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-10-2008, 08:47 AM
  5. Wet Feet.
    By otis_b in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-01-2008, 04:23 AM
