Thread: VW PASSAT ajm/atj engine matches
  1. Question VW PASSAT ajm/atj engine matches
    Feb 2014
    norway
    Can anyone say witch angine blocks will match for AJM/ATJ cylinder block?
    i have a hole in engine block and looking for replace/part engine, but i dont know witch engine codes will match for AJM/ATJ cylinder head..
  2. Re: VW PASSAT ajm/atj engine matches
    london/ UK
    I would look for a ARL pd 150 block if you thinking of any power upgrades, it's the strongest block you can get from the 1.9Tdi engines:stronger rods, lower compression pistons, better oil cooling jets and a forged crankshaft. Use your injectors and ancillaries and everything will bolt on. You might have a few issues with the clutch, for some reason the clutch and flywheel are particular to the PD115, nothing fits from the later models-something to do with the gearbox being different !
  3. Re: VW PASSAT ajm/atj engine matches
    Feb 2014
    norway
    i'm looking to replace engine block. not planing power upgrades
    a friend said i should try 1Z block or AFN , but AJM cylinder block is bit wider then 1Z . (engine 1.9)
    so best match is same engine block with same code ? (AJM/ATJ ) 1.9 (car is passat 2000)
    Any earlier model blocks wount do ? ex: AFN ?
  4. Re: VW PASSAT ajm/atj engine matches
    Feb 2014
    norway
    Going for AFN/1Z engine instead. gonna swap 01E gearbox to it and new wiring, ecu , 'n so on
    Will make notes and pics incase someone else needs to do it in future
  5. Re: VW PASSAT ajm/atj engine matches
    Jun 2012
    camberley surrey
    try any of these eBay item numbers for ATJ/ATM engines
    161119881587
    131102913969
    111202518027
    200821730397
  1. AWX or AJM engine??
    By Adman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-01-2013, 11:42 PM
  2. Audi A4 AJM TDi engine into my AJM MK4 Golf??
    By Digidick in forum Golf MK4 - 1999 - 2004
    Last Post: 26-03-2012, 11:34 AM
  3. Service parts that matches my passat 140
    By Sti_Prodrive in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-08-2011, 11:59 PM
  4. Injectors ATJ same as AJM?
    By MagicMat in forum Golf MK4 - 1999 - 2004
    Last Post: 22-12-2009, 01:43 PM
  5. Question Engine stalls 2000 ATJ
    By Gaza 83 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2009, 03:46 PM
