Thread: Is this normal for a speaker install or will I have a problem down the line?...
  1. Is this normal for a speaker install or will I have a problem down the line?...
    Aug 2007
    Hampshire
    I've posted this in the ICE section as well!
    I've had my B6 Passat in for a water test due to a front footwell damp carpet and have found out that it's coming from a blocked drain hole in the engine bay. Well they have sorted that out, but at the time checked the door area after taking the door cards off.
    Last year I had some new speakers and an amp fitted by another company (who I know very well for a number of years) and had a small issue with some rattling from the door area. It went back in and the company sorted this out, and I have not had any problems since.
    My friend at the garage sorting the leak out said he was a shocked to see the 'tin foil' around the speaker installation when they were investigating the leak problem
    I was just wondering if by the pics attached there was a real problem with the way the work was done and if I should be worried or annoyed! To his eyes it looks a bit shoddy.
    Any thoughts anyone...
  2. Re: Is this normal for a speaker install or will I have a problem down the line?...
    Dec 2006
    Stoke/Congleton
    At first I thought it was a botch job but I was concentrating the tin foil description, if you look closely it doesn't look like tin foil there is some kind of pattern on it like some specialist sound proofing.It might be the speakers are so powerful they need to try and stop the sound/vibration from traveling Down the door.
    I don't know if this is standard practice or anything else about it other than it looks like some specialist material.
  3. Re: Is this normal for a speaker install or will I have a problem down the line?...
    Norfolk
    That is just sound deadening mat. Normal stuff to use.
  4. Is this normal for a speaker install or will I have a problem down the line?...
    mjhamilton Guest
    That's dynomat - if you look at the price if this stuff it will put your mind at rest
  5. Re: Is this normal for a speaker install or will I have a problem down the line?...
    Sep 2008
    SE London
    There's also stuff called Fatmat around
  6. Re: Is this normal for a speaker install or will I have a problem down the line?...
    Dec 2009
    14 Post(s)
    An ICE thread :-):-):-):-). Brings back memories of almost 20yrs ago!!.
    As the other guys have said fat mat or dynamat. I would imagine around £50-£60 per door. Having said that ICE is a lot cheaper now than in the 90's. Its purpose is simply to stop rattles and insulate the sound. Also you would make sure the speakers are sealed to stop any air leakage from around the speakers.
  1. Replies: 3
    Last Post: 10-03-2014, 12:58 AM
  2. Question Audi A3 KM04 Reg, 3 door, Rear Speaker Install
    By Dansmith82 in forum In Car Entertainment
    Last Post: 21-03-2010, 07:03 PM
  3. Audi A3 KM04 Reg, 3 door, Rear Speaker Install
    By Dansmith82 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-03-2010, 05:25 PM
  4. 1997 A4 Rear Speaker Install
    By dwhite in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-02-2009, 09:42 AM
  5. Advice please - Sharan rear speaker install??
    By runningpuffingbilly in forum Touran - Sharan - Caravelle
    Last Post: 23-01-2007, 01:27 PM
