Thread: Touran Indicator Problem
  1. Touran Indicator Problem
    KieranQuaid Guest
    I have a serious intermittent indicator problem with my VW Touran 1.9tdi - 2004.
    When I indicate right it switches to left indication even though the stick stays in the right (up) position. If I keep my hand on it while indicating is bypasses the problem. I have no problem when I indicate left. Any ideas what is causing this problem please ?
  2. Re: Touran Indicator Problem
    Blairgowrie
    i wonder if the contacts in the stalk are at fault, if holding the stalk sorts it i would say that would be likely. on ebay they go for £10 - £20 so i would say worth a try, just check they are the same, is it a mk4 or 5 because: http://www.ebay.co.uk/itm/Volkswagen...#ht_626wt_1140
  3. Re: Touran Indicator Problem
    Blairgowrie
  4. Re: Touran Indicator Problem
    KieranQuaid Guest
    Much appreciated Lofty........I guess replacememt of the stalk is a garage job ?
    Regards, KQ
  5. Re: Touran Indicator Problem
    Blairgowrie
    No!!!! not at all, just undo the plastic shroud just passed the steering wheel, it will likely be held on with 4 or 5 screws from underneath. That should reveal the unit which will also be held on with 3 or 4 screws and will have a wiring loom attached which you should be able just to pull off, do reverse to fit other one.
    Easy job no splicing, just plug and play
  6. Re: Touran Indicator Problem
    KieranQuaid Guest
    Hi Lofty,
    That is great news......I really do appreciate you help. Thank You.
    Kieran
  7. Re: Touran Indicator Problem
    Blairgowrie
    Just think its a cheap way to perhaps fix the problem, removal and refit will be easy just common sense. If it doesnt solve the problem then you have your old stalk to sell on ebay and get your money back.
    Cant get cheaper than free.
  8. Re: Touran Indicator Problem
    KieranQuaid Guest
    Agreed.....
  9. Re: Touran Indicator Problem
    Feb 2014
    United Kingdom
    Hi
    Mine has recently started doing exactly the same. Its 55 plate. Did you manage to fix yours with a new stalk?
    Saran
  1. Indicator problem
    By dmhelsby in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-01-2011, 01:26 PM
  2. Touran indicator bulb wiring
    By steviestdi in forum Touran - Sharan - Caravelle
    Last Post: 22-03-2010, 09:08 PM
  3. A4 Indicator problem
    By saquince in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 15-02-2010, 11:28 PM
  4. Touran Service Indicator
    By reddb990 in forum Touran - Sharan - Caravelle
    Last Post: 19-12-2008, 09:59 PM
  5. indicator problem
    By graham.hassall in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-04-2007, 03:42 PM
