Thread: GTD 170 limp mode
Results 1 to 10 of 13
  1. GTD 170 limp mode
    Jan 2008
    My golf has recently started going into limp mode. I can cruise along at 65/70mph for a while and when i need to overtake by planting the throttle the limp mode kicks in. If i restart the car it goes away. It can be on a flat road surface or an incline (like a slip road)
    Ive done a vcds scan and here are the results:
    Address 01: Engine (J623-CFGB) Labels:. 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 BC HW: 03L 907 309 R
    Component: R4 2,0L EDC H23 7819
    Revision: 42H23--- Serial number: 00000000000000
    Coding: 001D0012040500080000
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_ECM20TDI01103L906018BC 003005
    ROD: EV_ECM20TDI01103L906018BB_003_VW36.rod
    VCID: 6CD772B2878BF124D4-8038
    1 Fault Found:
    5211 - Fuel Rail/System Pressure
    P0087 00 [101] - Too Low
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 146606 km
    Date: 2018.07.02
    Time: 14:31:25
    Engine speed: 2578.00 /min
    Normed load value: 99.6 %
    Vehicle speed: 108 km/h
    Coolant temperature: 89 °C
    Intake air temperature: 40 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 13.880 V
    Unlearning counter according OBD: 80
    Fuel temperature: 57.3 °C
    Mean injection quantity: 65.51 mg/stroke
    Rail pressure regulation: status-Bits 0-7: 5
    Fuel high pressure: actual value: 1.133e+006 hPa
    High fuel pressure: specified value: 1.3832e+006 hPa
    Pressure control valve adaptation factor: 0.9655
    Fuel level: 28.00 l
    Readiness: 0 0 0 0 0
    Could the pressure sensor be faulty as another time i scanned it said short to ground G247, or is it more like the lift pump is clogged and or fuel filter?
    Anyone had this issue before and if so what was the solution?
    Steve
  2. Re: GTD 170 limp mode
    131 Post(s)
    1978 Post(s)
    I would go for a new lift pump first.
  3. Re: GTD 170 limp mode
    Jan 2008
    cheers crasher - I will take out lift pump and clean it. Then ill change fuel filter. Failing that a lift pump it will be. and finally a new sensor
  4. Re: GTD 170 limp mode
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    VAG Error Code: 16471/15059/10116/5211/5212/5227/5231/2838/000135
    EOBD II Error Code: P0087
    Fault Location:
    Fuel Rail/System Pressure - Too Low/Implausible Signal
    Possible Cause:
    Malfunction Indicator Lamp (MIL)(K83) active.
    Power Loss.
    Fuel pressure too low.
    Fuel supply pipe blockage.
    Fuel pressure sensor harness open circuit or shorted.
    Fuel pressure sensor harness electrical circuit poor connection.
    Blocked fuel filter.
    Visual Inspection of Hardware (Camshaft, Cam Follower, etc).
    Mechanical Deficiency of Hardware (worn or missing parts)
    Possible Solutions:
    Check/Replace all faulty Wiring/Connector(s).
    Check Measuring Value Blocks (MVB) for Fuel Pressure.
    Fuel trim activity 0.90 - 1.15.
    Output value rail pressure controller > 2 MPa.
    Difference between target and actual pressure > -16.38 bar.
    Fuel Rail Pressure Test with VCDS by Ross-Tech - YouTube
    Check for bent/squeezed Fuel Lines.
    Check Low Fuel Pressure System for Leaks.
    Check Fuel Filter & Filter in Fuel Pump.
    Check the Fuel Quantity supplied by the Fuel Pump (G6).
    Special Notes:
    Petrol/Gasoline:
    When found in
    2.0l
    TFSI:
    Check
    Fuel Pressure.
    Check Technical Service Bulletin (TSB) 2027458/01-11-19 (North American Region (NAR)), for an improved Fuel Pressure Sensor (G410).
    Check Technical Service Bulletin (TSB) 2015153/15-11-03 (North American Region (NAR)), for a worn Intake Cam Shaft (superseded Technical Service Bulletin (TSB) 15-10-02, 15-11-01 and 15-11-02).
    Check Technical Product Information (TPI) 2014143 (Rest of World (RoW)), for a worn Intake Camshaft.
    Check Technical Product Information (TPI) 2014909 (Rest of World (RoW)), for a worn Intake Camshaft. This Technical Product Information (TPI) does NOT list in the Audi A6 (4F) BPJ Engine even though it is effected as well,
    so check for a worn Intake Camshaft of these too! When found on 2009 Audi 3.2 FSI AVS Engines, if Diagnostic Trouble Code (DTC) 000022/P0016 is flagged,
    please see Technical Service Bulletin (TSB) 15-09-04.
    Diesel:
    When found on Common Rail TDI engines, please see Technical Service Bulletin (TSB) 01-10-11 (Technical Product Information (TPI) 2023624).
    When found on Audi Common Rail V6, V8 and V12 TDI engines, please see Technical Product Information (TPI) 2020693. After mechanical all repairs are made Fuel Pressure Regulator Valve (N276) may need to be adapted and the EDC may need to be flash updated on the Audi Dealer level.
    Tech Notes:
    There is a service bulletin for the following Volkswagen vehicles:
    Volkswagen Eos 2006-2007.
    Volkswagen GTI 2006-2007.
    Volkswagen Jetta 2005-2007.
    Volkswagen Passat 2006-2007.
    Volkswagen Passat Wagon 2006-2007.
    Volkswagen
    Factory Service Bulletin OBDII Code P0087
    When is the code detected?:
    The Engine Control Module (ECM) has determined that the fuel rail pressure is too low for a specific engine RPM.
    As taken from my new EOBD II Error Codes
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  5. Re: GTD 170 limp mode
    Jan 2008
    Update:
    Still no further along with this. Randomly going into limp mode. I have fitted new: in tank lift pump, fuel pressure sensor, fuel filter ( no metal detected in housing) and the control valve on top of the high pressure fuel pump.
    Is there a cam ollower issue for these CR tdi engines? Engine code CFGB.
    vehicle has a comprehensive vw service history.
    I cannot see any kinked fuel pipes.
    O did do a running fuel pressure test and figure were pretty close to be fair
    This is doing my nut in!
  6. Re: GTD 170 limp mode
    131 Post(s)
    1978 Post(s)
    Lift the back seat up again, take off the cover and take a picture of the fuel delivery unit and it’s pipes, then post it.
  7. Re: GTD 170 limp mode
    Jan 2008
    New lift pump - pipes refitted exactly as taken off.
  8. Re: GTD 170 limp mode
    131 Post(s)
    1978 Post(s)
    I think that is right, my pics and info are at work and if this bug I seem to have gets any worse I am not going in tomorrow.....
  9. Re: GTD 170 limp mode
    131 Post(s)
    1978 Post(s)
    Yes that is right, I have seen them the other way around and they still run!
  10. Re: GTD 170 limp mode
    Jan 2008
    Ok - where do I go from here? - some days it will do it several times and other days not at all.
  1. Replies: 5
    Last Post: 07-02-2013, 06:52 PM
  2. "Limp Mode" - Audi A4 2002 2.0 Sport in Shoutdown Mode
    By ARJ230580 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-09-2012, 11:14 PM
  3. Limp Mode
    By bbb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-03-2010, 11:45 PM
  4. Question Limp mode/safe mode
    By fourringsrus in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-01-2010, 02:06 PM
  5. Limp mode - think I'm going to cry!! lol
    By MikeMc in forum Golf MK4 - 1999 - 2004
    Last Post: 22-04-2009, 09:47 AM
