Thread: 2003 vw golf 1.9 TDI
  1. 2003 vw golf 1.9 TDI
    Feb 2014
    After bypassing egr valve, because of carbon problems ,check engine stays on and I'll clear it but keeps coming back any way to clear it permanently.
    Using Tapatalk
  2. Re: 2003 vw golf 1.9 TDI
    Pembrokeshire
    22 Post(s)
    ecu detects egr inoperative so puts light on. either fit new egr valve, get egr mapped out of ecu or sometimes a 4mm hole in the blanking plate works, but this defeats the objective of removing the egr. best to fit a new one really, thats probably cheaper than mapping it out.
  3. Re: 2003 vw golf 1.9 TDI
    Feb 2014
    Thanks for repl
    Using Tapatalk
  4. Re: 2003 vw golf 1.9 TDI
    Feb 2014
    Thanks for reply Zollaf, you seem to know a lot more about computer aspects of cars. I have no idea what you mean.
    Using Tapatalk
  5. Re: 2003 vw golf 1.9 TDI
    Pembrokeshire
    22 Post(s)
    someone with a computer that can download a new map onto your cars computer that eliminates the egr valve. basically your cars ecu knows the egr has been blanked off so will always put the light on. they don't normally tell you this when you buy the blanking kit.
  6. Re: 2003 vw golf 1.9 TDI
    Feb 2014
    Thanks Zollaf, that's more than I can do, I'm pretty new at computers, I assume you need special software for that.
    Using Tapatalk
  7. Re: 2003 vw golf 1.9 TDI
    Pembrokeshire
    22 Post(s)
    yes, your ecu is programmed by vw. remapping is where someone writes new map and downloads it onto your ecu. you can make the car faster and more fuel efficient by doing this, and also get rid of the egr valve. look at some of the site sponsors that do remapping and speak to one of them. it is indeed very specialised and not cheap. like i say, probably cheaper to get a new egr valve.
  1. value of 2003 golf gt tdi 130
    By ian.i in forum Golf MK4 - 1999 - 2004
    Last Post: 10-08-2010, 05:10 PM
  2. 2003 golf tdi 130
    By bokbok in forum Golf MK4 - 1999 - 2004
    Last Post: 31-08-2008, 10:24 PM
  3. 2003 VW Golf V TDi
    By rogertdi in forum New Member Introductions
    Last Post: 04-10-2007, 08:32 AM
  4. 2003 mk4 golf pd tdi clutch?
    By david everett in forum Golf MK4 - 1999 - 2004
    Last Post: 23-04-2007, 08:20 PM
  5. golf gt tdi 150 2003
    By fireblade901 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-11-2006, 09:53 PM
