Thread: P0407 Code
Results 1 to 10 of 15
  1. P0407 Code
    Feb 2014
    Belfast
    Firstly, Hello from Northern Ireland
    i have a VW Passat 1.6 Bluemotion 2010 and it has thrown up this code.
    It comes and goes, but now is more often there.
    I had the code read and I was told it was the EGR valve. So I took it to get it mapped and the levels that trigger the EGR valve raised so that it wouldn't come on as a fault again.
    A day later it was back on. I have also used EGR cleaner and no use.
    I bought a Vgate Scanner and the code is coming up as a P0407 $07E8 Generic, Exhaust Gas Recirculation Sensor B Circuit Low
    Can someone advise me the right steps to take to sort the problem out.
  2. Re: P0407 Code
    Aug 2011
    Meath
  3. Re: P0407 Code
    Norfolk
    Quote Originally Posted by Teamin View Post
    P0407 EGR Potentiometer (G212), Signal too Low
    Why would you get the egr values changed by mapping? that doesn't make sense. The error is not about egr flow, it is about an egr mechanical/electrical fault. Change the faulty part.
    0 2 0
  4. Re: P0407 Code
    Feb 2014
    Belfast
    Quote Originally Posted by martin1810 View Post
    My limited understanding is that you can go into the programming of the car and either shut the egr valve off or change the values that it kicks in. Hence cost of new egr valve plus 1 1/2 days labour against fiddling with the programme.
    What are the thoughts? I would rather ask a daft question than remain in ignorance
  5. Re: P0407 Code
    Feb 2014
    Belfast
    I should add, to pitch this at the right level for responses that I will be asking what does this particular egr valve look like, where is it and is the first step to clean it. My mechanical knowledge is very basic, but it am a quick learner!
    Thank you in advance !
  6. Re: P0407 Code
    Up North
    Your first post said you had used EGR cleaner. The valve is the same one you used the cleaner on. Sorry if that sounds a little sarcastic, I'm struggling for a more sympathetic way to phrase it.
    Martin's already given you the best advice. Change the part, or get someone else to do it for you. Unfortunately, it's not a cheap item for your engine (looking at the GSF website), but unless you are planning just to get the car in decent fettle to sell it on, it's the best long term option.
    While you're at it, get whatever values have been changed restored to original. If your mechanical knowledge is basic, it's never a good idea to try the automotive equivalent of brain surgery.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  7. Re: P0407 Code
    Norfolk
    Any tuner can change egr values in ecu file but you would still have this error so they would have to code that out too. I doubt they will want to do it for nothing. I suspect that getting the egr part changed will be cheaper.
  8. Re: P0407 Code
    Feb 2014
    Belfast
    Quote Originally Posted by Teflon View Post
    Teflon,don't worry about the sarcasm, I am prone to a little of it myself
    The EGR cleaner was the type that is sprayed into the air inlet on the clean side of the air filter. Hence my question as to point me in the right direction for the EGR valve ( as with different models and manufacturers it looks like it has different shapes and locations )
    Some sites talk about cleaning the valve and also checking the connections. I take it that this is worth trying before buying a new valve. Also looking at maybe buying a salvaged valve and putting it on to keep the cost down. Or not bother and put a new one on. If so where is the best place to buy one?
    When ai say my knowledge is basic I can find my way round a Haynes or Clymer manual for older motorbikes, but all this newly fangled electronic trickery has me wary
    Is there a diagram that will identify the location?
    Many Thanks for your comments!
  9. Re: P0407 Code
    Feb 2014
    Belfast
    [QUOTE=Doctle Odd;877107]16791/P0407/001031 - Ross-Tech Wiki[/QUOTE
    if I can locate the dammed thing :-)
  10. Re: P0407 Code
    Feb 2014
    Belfast
    Ok new EGR valve ordered and should be here before the weekend. Even though I have no idea where it is located.
    I take it that once I have seen it I will work that out
  1. Audi TT Chorus stereo code not with car, help needed getting code
    By acordery in forum TT - 8N Forum - 1998 - 2006
    Last Post: 09-08-2013, 02:38 AM
  2. Question 3TDI (BKN code) engine schematics and fault code listing
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2012, 02:41 PM
  3. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  4. A6 block code engine code id
    By scottrrobbie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-12-2010, 03:54 AM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
