Thread: Engine Management Light On - A4 1.8T Cabriolet (2005 MY)
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. Engine Management Light On - A4 1.8T Cabriolet (2005 MY)
    Jul 2012
    Grantham
    Hi folks,
    My engine management light recently came on. There is no difference in engine performance so i am led to believe this could be simply a Lambda Sensor failure
    I intend to replace the front sensor, but wondered where was the best place to buy a sensor
    I have had a look at the one fitted has 5 wires
    Would members suggest doing anything else either prior, during or after sensor replacement
    I do not have access to VAGCOM or anything to interregate the codes
    Thanks in advance
    Pete
  2. Re: Engine Management Light On - A4 1.8T Cabriolet (2005 MY)
    Southern County Softy
    20 Post(s)
    Without a scan you have no idea what the fault is.
    How do you know changing the lambda will fix it.
    bloody smart phones....
    A4 2.5 tdi QS (mapped)
  3. Re: Engine Management Light On - A4 1.8T Cabriolet (2005 MY)
    Jul 2012
    Grantham
    I'm only guessing given that the car is still running fine and not gone into limp home mode
    I have had the MAF connector off and it ran like a bag of nails so have discounted the MAF
  4. Re: Engine Management Light On - A4 1.8T Cabriolet (2005 MY)
    20 Post(s)
    Don't guess, scan.
    By disconnecting the MAF you now definitely have a fault code...
  5. Re: Engine Management Light On - A4 1.8T Cabriolet (2005 MY)
    Jul 2012
    Grantham
    Quote Originally Posted by kite View Post
    Don't guess, scan.
    Perhaps you havent read the original post, I have NO WAY of reading the codes
  6. Re: Engine Management Light On - A4 1.8T Cabriolet (2005 MY)
    46 Post(s)
    Quote Originally Posted by pvcprinting View Post
    Now you do - VWAF User Location Map - VCDS - Google Maps
    Make 4 more useful posts and you can PM if there is anybody near.
  7. Re: Engine Management Light On - A4 1.8T Cabriolet (2005 MY)
    mjhamilton Guest
    Or buy a £5 cable and use vcds-lite to read the basics
  8. Re: Engine Management Light On - A4 1.8T Cabriolet (2005 MY)
    20 Post(s)
    Just change the sensor, if thst doesn't work change something else...
  9. Re: Engine Management Light On - A4 1.8T Cabriolet (2005 MY)
    Jul 2012
    Grantham
    Quote Originally Posted by mjhamilton View Post
    That could be an option, what cable would be required?
  10. Re: Engine Management Light On - A4 1.8T Cabriolet (2005 MY)
    Jul 2012
    Grantham
    Also meant to ask if vcds-lite is something that runs from a laptop and is it able to reset any codes?
  1. Please Help 2002 Audi A4 1.8t Oil warning light after 5 mins of driving then engine management light comes on
    By ScottyDoo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-09-2013, 01:02 PM
  2. A6 C6 2005 2.0 TDI Engine Management Light!! HELPPP
    By nemerkh in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-11-2009, 09:39 AM
  3. Please Help 2005 Polo - Engine Management Unit Problem
    By Kathryn1980 in forum Polo - Derby - Lupo - Fox
    Last Post: 20-05-2009, 07:06 AM
  4. Please Help Engine management light is on, Fan turn on when engine is off, made the battery flat, help
    By shinghu in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-01-2009, 02:15 AM
  5. Change rear light bulbs on A4 Cabriolet 2005
    By Gordonpm in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 18-03-2008, 03:29 PM
