Thread: Radio controlled clock module on B8
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. Re: Radio controlled clock module on B8
    #21
    Dec 2008
    12 Post(s)
    Hey guys, I've manage to fix the antenna. I purchased a new one and mounted it in rear bumper where it normally sits but for a 2-3 days nothing happened. Then I was doing some other coding with vcds and parallel with that I reverted radio clock sync interval on 10 minutes which is a factory setting. Later in the evening I had to go somewhere and when I opened car door there it was
    I dont know why it didnt work on 2 minutes sync interval, very strange!
  2. Re: Radio controlled clock module on B8
    #22
    Sep 2011
    Lurking over a keyboard ...
    Great news , I have one question do you now see anything extra in mvb 2 in ins.cluster?
  3. Re: Radio controlled clock module on B8
    #23
    Dec 2008
    12 Post(s)
    Still nothing mate, there is no any other values in those fields, only mileage and fuel tank level. Channel 27 (I think) is now updated with sync time and other related stuff
  4. Re: Radio controlled clock module on B8
    #24
    Sep 2011
    Thanks ...
    Another question , in MVB 27 data window 1 previously you had status as 000001 what does it say now?
    Also if you hover over that data does a helper balloon appear with info?
    Cheer!
  5. Re: Radio controlled clock module on B8
    #25
    Dec 2008
    12 Post(s)
    I think it says 000011 now but I'm not sure. I'll check that in a future and post the screenshots here.
  6. Re: Radio controlled clock module on B8
    #26
    Sep 2011
    Please do hover the mouse pointer over the data to see if a helper balloon comes up with some explanation on the values.
  7. Re: Radio controlled clock module on B8
    #27
    Dec 2008
    12 Post(s)
    Ok!
    Sent from my LG-D855 using Tapatalk
  8. Re: Radio controlled clock module on B8
    #28
    Dec 2008
    12 Post(s)
    Here are the screenshot
    No aditional info when hovering with mouse pointer over data
  9. Re: Radio controlled clock module on B8
    #29
    Nov 2009
    Cork
    Quote Originally Posted by Zenerdiode View Post
    Sorry, older Audis had a separate module pinned to the back of the cluster.
    The antenna/module is behind the rear bumper cover on the left hand side. It is attached to the support bar - rather than the cover itself. It has a three pin connector and is wired directly to the dash on the 32-pin connector. There is an adaptation value in 17-instruments to say how often it updates; the value being zero if not fitted. I don't know if there is a bit to set in long-coding.
    If you want to retrofit, you will need the following:
    • 4B0 919 145 B - Receiver for radio-controlled clock
    • N 104 128 04 - bolt (x2)
    • 8K0 973 703 - plug coupler
    You will also need a set of repair wires with the correct pins for the above plug coupler and the dash plug coupler (1J0 972 977 G).
    • Pin 1 to dash pin 24
    • Pin 2 to ground
    • Pin 3 to dash pin 23
    Let me know how you get on - as I might have a go myself.
    Hi, which repair wires did you use for this? Am I correct in assuming you don't need the dash plug?
    Sent from my Brain via my Keyboard
    AUDI A4 Avant 2.0TDI S Line
    | My Slipper |
  1. radio and speaking clock
    By zollaf in forum Chat - Completely Off Topic
    Last Post: 23-08-2013, 09:08 PM
  2. Set radio contolled clock
    By Janfi in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-04-2013, 12:41 PM
  3. Question Clock time incorrect and radio in safe mode
    By Dee-C in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-03-2012, 03:59 PM
  4. Question DAB radio module for Symphony?
    By SteveSmythe in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-01-2011, 05:03 PM
  5. Flying Radio-controlled planes
    By Bugbear in forum Chat - Completely Off Topic
    Last Post: 13-11-2007, 09:48 AM
