Thread: Radio controlled clock module on B8
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. Radio controlled clock module on B8
    Dec 2008
    12 Post(s)
    Hi all! I need help with this. Radio controlled clock isnt functioning as he should. I've enabled this in MMI but theres no radio antena icon on DIS near clock and nothing happens. I left it on for a few days but nothing. How to check is there somewhere a radio clock module? Where is its location on the car? Is it like on b6 under rear bumper? It's a little bit strange if I have that function on MMI but no signal. Just for information my country (Croatia) is covered good with radio clock signal from Frankfurt in Germany. I had this on my ex car b6 and was working fine.
    Sent from my GT-P3110 using Tapatalk 2
  2. Re: Radio controlled clock module on B8
    Jan 2008
    The clock antenna is fitted behind the rear bumper; on the left hand mount. You have to have the antenna (under bumper), module (on back of instrument cluster) and enabled in 17-Instruments for it to work.
    MY2009 A4 Saloon 2.0 TFSI quattro S-line Exec - Aruba Blue, 19" alloys, Convenience Key, Sunroof, Adaptive Lights, Anti-dazzle Folding Mirrors, Rear Sun Blind, Heated Full Leather with Memory, Storage/Light Packs, Audi Hold Assist, Adaptive Cruise Control, Parking System Advanced, Privacy Glass, Rear Airbags, TPMS. MMI 2G with B&O Sound System, DAB Radio, DVB TV, AMI and Bluetooth Phone prep High with Privacy Handset.
  3. Re: Radio controlled clock module on B8
    Dec 2008
    12 Post(s)
    Quote Originally Posted by Zenerdiode View Post
    So its about rear bumper? I dismantled instrument cluster but found nothing there, no additional plug-in just the main cable.
  4. Re: Radio controlled clock module on B8
    Jan 2008
    Sorry, older Audis had a separate module pinned to the back of the cluster.
    The antenna/module is behind the rear bumper cover on the left hand side. It is attached to the support bar - rather than the cover itself. It has a three pin connector and is wired directly to the dash on the 32-pin connector. There is an adaptation value in 17-instruments to say how often it updates; the value being zero if not fitted. I don't know if there is a bit to set in long-coding.
    If you want to retrofit, you will need the following:
    • 4B0 919 145 B - Receiver for radio-controlled clock
    • N 104 128 04 - bolt (x2)
    • 8K0 973 703 - plug coupler
    You will also need a set of repair wires with the correct pins for the above plug coupler and the dash plug coupler (1J0 972 977 G).
    • Pin 1 to dash pin 24
    • Pin 2 to ground
    • Pin 3 to dash pin 23
    Let me know how you get on - as I might have a go myself.
  5. Re: Radio controlled clock module on B8
    Dec 2008
    12 Post(s)
    • Pin 2 to ground
    Ok, thats quite usefull information. Can I find out over VCDS if my rear bumper module is malfunctioning just to avoid bumper dismantle? If the VCDS shows an error then I'll go for replacement. Thanks!
  6. Re: Radio controlled clock module on B8
    Nov 2009
    46 Post(s)
    Could you not just adjust it manually?
  7. Re: Radio controlled clock module on B8
    Nov 2009
    Cork
    • Pin 2 to ground
    Hi, which repair wires did you use for this? Am I correct in assuming you don't need the dash plug?
    Sent from my Brain via my Keyboard
    AUDI A4 Avant 2.0TDI S Line
    | My Slipper |
  8. Re: Radio controlled clock module on B8
    Dec 2008
    12 Post(s)
    Situation update.: few days ago I went to my friends who has original Audi VAS and he tried to activate antena module by starting a sync but no luck. Antenna icon didnt appear on DIS. He checked is module faulty maybe but all is ok.
    Sent from my GT-I9505 using Tapatalk
  9. Re: Radio controlled clock module on B8
    Dec 2008
    12 Post(s)
    Update II
    Few days ago I tryed to off /on the remote clock with VCDS but again nothing happened. It is always turned on in MMI but icon didnt appeared. If theres a fault on antenna module should I see it in VCDS module fault reader?
  10. Re: Radio controlled clock module on B8
    Sep 2011
    Lurking over a keyboard ...
    Recently I was looking into this concerning a thread on another forum and radio clock for the Audi A6 4F/C6.
    If you view measuring block 2 data window 2 in module 17 :-
    test off if no radio clock coded into module 17.
    n.OK malfunction in receiver or if radio clock coded in but receiver not fitted.
    OK receiver working.
    When I coded in radio clock into my A6 4F/C6 when it does not have a receiver for one there were no DTC's in module 17 or autoscan log, only MVB 2 data window 2 in module 17 showed Receiver N.OK.
    Have you visually checked you have receiver?
  1. radio and speaking clock
    By zollaf in forum Chat - Completely Off Topic
    Last Post: 23-08-2013, 09:08 PM
  2. Set radio contolled clock
    By Janfi in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-04-2013, 12:41 PM
  3. Question Clock time incorrect and radio in safe mode
    By Dee-C in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-03-2012, 03:59 PM
  4. Question DAB radio module for Symphony?
    By SteveSmythe in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-01-2011, 05:03 PM
  5. Flying Radio-controlled planes
    By Bugbear in forum Chat - Completely Off Topic
    Last Post: 13-11-2007, 09:48 AM
