Thread: Can you fit cruise control on a car that didn't come with it?
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Can you fit cruise control on a car that didn't come with it?
    Dec 2008
    Hope the question makes sense. I have an A3, 2004 2.0 TDI, BKD engine that didn't come with cruise control. Obviously that would have been an optional extra. WOuld it be possible to fit it to the car? and any idea on what sort of cost I'd be looking at?
    My daily commute is 65 miles each way on the motorway and would LOVE cruise control!!
  2. Can you fit cruise control on a car that didn't come with it?
    Nov 2009
    46 Post(s)
    Anything is possible - you may or may not need the extra wire going to the ecu but a auto scan from vcds will be needed to see which steering ecu you have.
    I retrofitted it to my 2009 - all it is is remove the airbag, steering wheel, lower steering trim, upper steering trim, slip ring, steering angle sensor and the steering ecu itself and insert the new twin stalk with new lower trim to accommodate the new stalk.
    Sounds worse than it is actually is - I had mine done within an hour but word of advice - you will need a m12 spline bit and a t9 torx
    NHN or a8 tech could advise on the possible extra wire needed
    Where abouts are you?
  3. Re: Can you fit cruise control on a car that didn't come with it?
    Dec 2008
    so there wouldnt be any engine modifications then? Its just as 'simple' as adding the switch?
  4. Can you fit cruise control on a car that didn't come with it?
    Nov 2009
    46 Post(s)
    Just enabling it with vcds is needed afterwards
    Cost - stalks are as little as £35-50 and if you need a m12 and t9 factor in those aswell and if you're getting someone to do it for you or fit it yourself.
    Autoscan is needed and make sure you research heavily as there are differences in some of the steering ecu.
  5. Re: Can you fit cruise control on a car that didn't come with it?
    Dec 2008
    Hmm, that is interesting.. I had assumed it would cost lots so wouldnt bother! Think I may well get this done in that case - my partners dad has VCDS and is a whiz with Audi's so could probably chuck him 50 quid and have it all done for under £100! Brilliant thanks!
  6. Can you fit cruise control on a car that didn't come with it?
    Nov 2009
    46 Post(s)
    Get him to do an autoscan and post it up here
  7. Can you fit cruise control on a car that didn't come with it?
    Nov 2009
    46 Post(s)
    I forgot - the lower steering trim is about £20 from eBay.de and I think about the same from Audi themselves.
  8. Re: Can you fit cruise control on a car that didn't come with it?
    Dec 2008
    How can I find out what steering ecu I have? Just by scanning? And how do I know if I need the extra wire?
    how sensitive is the airbag when you take the steering wheel off? Don't ent any 'mishaps!'
    sorry for all the questions!
  9. Can you fit cruise control on a car that didn't come with it?
    Nov 2009
    46 Post(s)
    Quote Originally Posted by henners38 View Post
    Yes you will need to do an autoscan to get the ecu revision then we can advise further
    From what I've read online it's only usually the petrol models that need it but ill let Nigel confirm or correct me on that
    I had no issues with mine but before working on the car I disconnected the battery then left it 30 minutes to settle down before doing anything. Remember to place it down with the audi logo facing upwards.
  10. Re: Can you fit cruise control on a car that didn't come with it?
    Jan 2012
    Coding Something
    The kit is about £90-£100 from audi, trims can be got if you hunt about, but no guarantee its not scratched tbh which is why I tend to buy new when fitting.
    If the pic in your sig is your car, it may need the extra wire run tbh as its an original double grill A3, so some didnt have the wire.
    Also age wise it may not have a compatible module fitted for the cruise, so as advised by chris, it needs a scan & you will need vcds to cear airbag lights & code engine/steering module, just be careful removing the module & slip ring as its easy to break things.
  1. Question Retro Fit Cruise Control...
    By ToMBoY_C in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-12-2010, 11:49 PM
  2. retro fit cruise control
    By taff503 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-05-2009, 04:32 PM
  3. Cruise Control Retro-Fit
    By Judd222 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-11-2008, 08:43 AM
  4. Question retro fit cruise control
    By Mr.I Kenney in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-07-2008, 04:18 PM
