Thread: VCDS Tricks for the A7
Page 17 of 18 FirstFirst ... 715161718 LastLast
Results 161 to 170 of 175
  1. Re: VCDS Tricks for the A7
    Dec 2019
    That’s weird. Maybe somebody else knows how to activate it. It should be there...
  2. Re: VCDS Tricks for the A7
    Jan 2020
    United Kingdom
    Quote Originally Posted by alex.tsc View Post
    Ok i will try to connect someone that works with audis and thanks for all your help on everything
  3. Re: VCDS Tricks for the A7
    Feb 2016
    Hungary
    116 Post(s)
    Quote Originally Posted by tomfake56 View Post
    Hi i have went to that place in the mmi but it only says about long press for windows
    If I remember well, then it was a common problem with the early FL models. I think, you should go to an Audi dealer, and they will replace the MMI version with the new one - probably for free, as it was a factory failure.
    Audi Q7/4M MY2016, 3.0 TDI/200 KW Quattro
  4. Re: VCDS Tricks for the A7
    Dec 2019
    Any info about the green menu? We can activate it, access it but what exactly is it for? Can we make use of it (without breaking our car of course)?
  5. Re: VCDS Tricks for the A7
    Oct 2019
    Peterborough, England
    23 Post(s)
    The green menu allows you to change or activate some more hidden menus so they can show up on the MMI.
    It also allows you to change settings and timings and all sorts of stuff.
    Before you start though, you need to know that it can be VERY dangerous.... It CAN break your car...
    There are various videos on you tube showing you how to get it and some of the bits it can do.
    The plethora of options in there are vast. I cannot stress how careful you have to be in it.
    You usually need VCDS to activate it in the first place.
  6. Re: VCDS Tricks for the A7
    Dec 2019
    I own VCDS and already made some small changes but I will not enter in the green menu without any specialist next to me. Thanks
  7. Re: VCDS Tricks for the A7
    Feb 2016
    Hungary
    116 Post(s)
    If I remember well, there was only one case which required to usage of the Green menu.
    It was the "NAD operation mode", which should be enabled there if you want to use the built in SIM card and the Bluetooth in the same time.
  8. Re: VCDS Tricks for the A7
    Dec 2019
    Ok soooo..I think I made a booboo, meaning I entered green menu to activate battery gauge level by accessing CAR -CAREXTDEVICE-BATT GAUGE LEVEL and then the last option to ser the battery to 5. Got out of the menu and hit menu-mid hutton-upper right corner button to reset it. But now the battery is not in the menu and this is showing over every menu I go in, even in the videoclips. I tried to set the battery option back to 0 but no luck. What can I do to reset it?
  9. Re: VCDS Tricks for the A7
    May 2008
    15 Post(s)
    Has anyone managed to get VIM working on the 4K A7?
  10. Re: VCDS Tricks for the A7
    May 2008
    15 Post(s)
    I managed to fluke this with my OBDELEVEN PRO without buying 100 credits.
  1. A6 C7 VCDS Tricks
    By MFGF in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 18-03-2024, 10:39 AM
  2. Audi A4 B8 - VAG.com Tricks
    By 73kingstonroad in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-03-2021, 05:34 PM
  3. How To Tricks of the trade
    By eonbkuk in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-07-2013, 01:40 PM
  4. Audi A6 Tricks ??????????????
    By slice636 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2009, 12:27 PM
  5. Question vag com tricks?
    By andymartin045 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-09-2009, 07:43 PM
